Check Engine Lite
Old Apr 18, 2006 | 03:49 PM
jefe's Avatar
jefe
Default Check Engine Lite
Check Engine Light came on so I ran the diagnostics and it shows P1416 Secondary Air Injection (AIR) System Bank 2. First, what is it? And second, how do you fix it? I have an 03 Z06 with 25K miles and the only mods are an "X" pipe, Borla Stingers, NGK plugs, and a modded intake cover with a K&N filter. Thanks Guys.
Note: It shows History and Current.
This is also posted in the Z06 Discussion.
Jefe
Old Apr 18, 2006 | 04:36 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Jefe
First off, don't sweat this code. It is an Air system sensor. Usually indicating a problem with the passenger side check valve (real bear to get to.)
Have a look at this thread:
http://forums.corvetteforum.com/show...416&forum_id=1
Paul
