Door Lock question
Old Apr 19, 2006 | 07:26 PM
Hrdtop00's Avatar
Hrdtop00
Default Door Lock question
My door lock switch on the drivers side door is acting kind of strange. When you depress the switch to lock the doors, it only locks the passenger side door. However, if you manually lock it or use the remote to lock it, the switch on the door panel will unlock both doors. Strange! Is it the switch or the control module in the door? Anyone experienced this in their C5?
Old Apr 19, 2006 | 07:29 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
I would try cycling back through the DIC options first. If that doesn't do it, I suspect it is the switch.
Old Apr 19, 2006 | 07:44 PM
adown's Avatar
adown
I just had this same thing on my 00 cpe. It ended up being the electronic controller under the door panel. $197. I pulled both panels off and swapped the pass controler to the dr side and it worked.
To Door Lock question
