335-30-18 tires
Old Apr 19, 2006 | 09:27 PM
smknvette's Avatar
smknvette
Default 335-30-18 tires
Hey guys, was wondering if 335-30-18's would fit on 18x11 Z07 wheels? If so how far would it stick out?
Old Apr 19, 2006 | 09:30 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
that will work, but they should really be on a 12" rim. As for the offset i can't answer that for you.
Old Apr 19, 2006 | 09:43 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
According to Michelin's web site - a 335-30x18 really should be on a 12" wide wheel as the minimum, just as Chris stated. You can install it on an 11" wide wheel, but the reality is that the sidewall will be buckled in almost to the point that it could be detrimental to the tire. I wouldn't do it.
http://www.michelinman.com/assets/pd...pilotsport.pdf
With a 12" wide wheel - the tires will stick out - unless you find a wheel with enough offset to allow it to tuck under, but then you more than likely have issues with the tires rubbing the fender (inside and outside). In order to make that work properly - you should consider mini-tubbing. If you select a wheel with enough offset to clear the inner fender, and if your car is lowered, you might have an issue with the bottom lip of the fender making contact with the tire tread in bumps and cornering (anytime the suspension is compressed).
So will it work? Maybe. Is it a good idea - I'd say no. Inmo, of course.
Old Apr 19, 2006 | 10:29 PM
jdmvette's Avatar
jdmvette
Night Owl for life
335/30/18s on an 11" Z07 wheel:
Stick out abot 3/4".
I am going to 305 or 315 soon.
Old Apr 19, 2006 | 10:40 PM
tnsyty's Avatar
tnsyty
those are my wheels, lol. what size are your fronts?
To 335-30-18 tires
