GM Bra installation
Thanks for any help
You can do this with removing the wheels, just turn the wheel as far to one side as possible to give yourself some room and then do the opposite side the same way.Have fun.
Micah
Micah
No ramps or jacking needed to install, but the screws do suck hard.
Thanks for any help
If you have a radiator screen, be prepared to get a finger or a bent-nose pick or screwdriver above/behind the lower lip of the front fascia. The bra's replacement screws are fairly short, so getting them to start in the nut wasn't going to happen until I found a way to press on the nut from behind in order to force together the snap-screw/fascia/screen/panel nut stack. Once the first thread of each catchs, they grab and tighten down ok.
The inner wheel well nuts have a *tiny* locking tab on the stamped nut which engages the hole on the fender panel. Prying these "zip-nuts" off is a pita, in large part because this little tab hangs up and won't let go. Knowing it's there should help you focus on what twists/turns/prying you need to do to get the nuts to slide off the fender flange.
If you have problems with the rubber nuts from the bra kit spinning in the holes before they get tight enough to expand, you can remove the bottom access panel under the turn signal, and reach up with pliers to hold the rubber part from behind. If you do this, you'll probably need a second person to turn the screwdriver, unless you're a contortionist
And if you're as ham-fisted as me, you'll probably have to remove the access panel(s) anyway to retrieve the zip-nuts that pop off and fall into the fascia before you can catch them.
But once the snaps are in place the bra is installed ez each time you use it
These work great in the wheel wells. Other than that, it is a snap to put on and take off. You'll enjoy it and the protection it offers.
Exactly what I did and they work great ! No problems putting them on and bra goes on easy in a couple of minutes.
Never trust a dealership to do what you can do yourself
if all else fails, simply follow the directions
