Fog Light Replacement
Old Apr 20, 2006 | 11:14 PM
gtoformula400's Avatar
gtoformula400
Default Fog Light Replacement
Im replacing the fog light bulbs in my vette and was curious if there are any tips or tricks for this... In my defense I havnt had a chance to check things out for myself yet so if its mindnumbingly easy please excuse my unnecesary question Thanks
-Joe
Old Apr 21, 2006 | 12:10 AM
BanditDude's Avatar
BanditDude
-Joe
With the hood open, use the manual controls to raise the headlights (you'll have to remove a rubber cover and turn it for ~30 seconds for each light). Then, remove the 3 (?) screws that secure the black plastic cover that goes around each headlight. Gently remove the cover.
If your hands aren't too large, you should now be able to reach through the opening by the headlight and remove the connector from the back of the fog light. Now give the bulb a 1/4 turn to remove.
Reverse the process to assemble, and enjoy.
Old Apr 21, 2006 | 12:11 AM
BrianWe's Avatar
BrianWe
I had to temporarily take out the fog lights when I installed my WCC cold air screens. You can do it just by reaching in under the hood if unless you have linebacker type arms. The way I recall, it is only a few screws. They rest in the car via a lip on the top. So you can put them in, pull your arm out to grab the screws and then put them in. I don't recall having any trouble with the wiring either.
Old Apr 21, 2006 | 06:48 AM
gtoformula400
Great guys!!! Thanks for the help
To Fog Light Replacement
