3.42 gears
Old Apr 21, 2006 | 02:43 PM
slverc5's Avatar
slverc5
Default 3.42 gears
Got my 3.42 gears installed yesterday and picked up my car today. I noticed a little ooomph from and the and I can say that I am satisfied Just one issue and I thought you guys can help me out.
On my way home wiht the windows closed, I started hearing a faint humming noise everytime I stepped on the gas pedal and it's coming from the rear. About 3-4 miles before I reach home, the humming got a little stronger, still happens when I step on my gas pedal, but it is accompanied by like a faint grinding noise everytime I stepped on and off the gas pedal ( the grinding sound sounds like when you shift gears but not as loud) I don't smell anything on the outside, car runs fine, it's just that annoying noise, and I don't hear any real loud grinding noise, just that faint humming. Can you guys help me with this one. Thanks.
Old Apr 21, 2006 | 03:02 PM
SLPRC5's Avatar
SLPRC5
Is it used gear? Was it the whole differetial you had swaped out or was it gears? If it was a used set they could be worn..I'd try a different brand of gear oil..such as Royal purple gear oil. If it was a set of gears installed , they maybe setup wrong...others will chime in on this with better answears maybe..
Good luck
Old Apr 21, 2006 | 03:04 PM
I X L R 8's Avatar
I X L R 8
I dont experience any of that.
Doesn't sound right too me.
All you experienced was a little bit of ooooph?
I had 2.73's
It felt like I bolted a hundred horsepower to the car when I put the 3'42's in.
Old Apr 21, 2006 | 03:05 PM
I X L R 8's Avatar
I X L R 8
Good luck
Or this could be backwards.
It could be a brand new carrier and gears. It would seem a brand new set would be more inclined to hum a little thru the gears.
Old Apr 21, 2006 | 03:07 PM
slverc5's Avatar
slverc5
Good luck
It's a new set of gears I got from a forum member.The job was a gear swap not a whole unit swap. The shop did use Royal Purple. I did talk to the shop and I'll bring it back tuesday. But anymore inputs from you guys is greatly appreciated.
Old Apr 21, 2006 | 03:09 PM
99quicksilver's Avatar
99quicksilver
St. Jude Donor '03-'04-'05
You need to take it easy for the first few hundred miles....
I X L R 8's Avatar
I X L R 8
See I told you so.
lol
Old Apr 21, 2006 | 03:10 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have heard some nightmare stories about just swapping the gears, instead of doing a whole DIFF swap. Take it back to the shop and let them evaluate it for you. I wouldn't play a guessing game to much long, you maybe able to get it fixed without having to replace to much.
Good luck and keep us posted.
Micah
Old Apr 21, 2006 | 03:11 PM
slverc5's Avatar
slverc5
I had 2.73's
Well, I was coming from a 3.15 going to 3.42, so I already had some ooompphhh to begin with
Old Apr 21, 2006 | 03:14 PM
I X L R 8's Avatar
I X L R 8
Yeah thats totally different.
coming from 3.15's into 3.42's.
You're lucky to never have experienced 2.73's...........lol
It was horrible.
Old Apr 21, 2006 | 06:08 PM
Dark-Knight's Avatar
Dark-Knight
Did you break 'em in as perscribed?
Old Apr 21, 2006 | 06:19 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
I had 2.73's
Me too!!!!!!!!
Old Apr 21, 2006 | 06:30 PM
black98c5's Avatar
black98c5
Yup, 2:73s suck . i cant wait to have my yank ss3500 and 3:42s installed.
Old Apr 22, 2006 | 03:13 AM
slverc5's Avatar
slverc5
Well, I'll bring it back tuesday. The shop was very fast with their response when I e-mailed them. So I don't think I will have any problem with them. Hopefully it's nothing. I'll give an update for future reference for members who will do the same gear swap.
Old Apr 22, 2006 | 03:57 AM
Bracketman's Avatar
Bracketman
Is there any type of problems that can occur by putting the 3.42 gear in (short term/long term) if your running stock 3.15's?
Old Apr 22, 2006 | 08:34 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Agree w/ above. There shouldn't be any noise coming from the new gears. Take the car back and have it evaluated. Good luck.....
To 3.42 gears
