Windshield Washer Fluid Ooze
Old Apr 22, 2006 | 09:07 AM
rwsr50's Avatar
rwsr50
Default Windshield Washer Fluid Ooze
Anybody else have a problem with their windshield washer fluid oozing out around the cap on the reservoir? That seems to be the only thing messing up my clean engine compartment. I keep wiping it off, and each time I look a little more has seeped out. I'm hoping after the level goes down it may not do this. I plan not to fill it back up but keep the level fairly low in the reservoir, as I never really use it anyhow.
Old Apr 22, 2006 | 09:10 AM
c4cruiser's Avatar
c4cruiser
The fluid might be expanding as the engine compartment heats up. Try siphioning out some of the fluid.
Old Apr 22, 2006 | 10:10 AM
You've got the right idea in not keeping the reservoir so full. I keep mine about 3/4 full and it seems to avoid the problem.
Old Apr 22, 2006 | 01:00 PM
steve8's Avatar
steve8
Definitely don't keep it full. At higher speeds, it can even weep out on your windshield.
Old Apr 22, 2006 | 01:37 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I solved the problem by removing the windshield wipers and placing very small caps on the windshield washer nozzles. They haven't leaked a drop since.
Old Apr 22, 2006 | 02:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There is a hole designed into the cap to let air in/out so the fluid flows correctly. Just don't fill it so hard. I learned the hard way when I was cleaning the bay and leaned on the bottle and a stream of fluid shot up and went all over the drivers side of the bay and the fender.
Old Apr 22, 2006 | 03:48 PM
rwsr50's Avatar
rwsr50
Yeah, I might have to siphon some out. I never added any, the fluid level is what it was when I bought the car. Come to think of it, I don't remember ever even looking in to see how full it is. I've just been wiping up around the cap.
To Windshield Washer Fluid Ooze
