Got in my daily driver (except for foul weather) after letting her sit for 3 days. Turned the key and....nothing. Battery was dead. I heard what sounded like an electric motor running but couldn't identify it. Got a jump (from the wife's VW ) and it's been fine since. It's happened before but I thought it had something to do with the passive unlock system - not the case. Any ideas?
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
What battery do you have?
The electric sound you heard was probable the fuel pump firing up...
If turns out to NOT be the battery, FWIW, I had the sensor in the ignition cylinder go bad... it would read the resistor in the key... you may want to clean the resistor (with some rubbing alcohol and a Q-Tip) in the key first.
