Sports Seats Electrical Problem
Old Apr 23, 2006 | 10:27 PM
majbillgsd's Avatar
majbillgsd
Default Sports Seats Electrical Problem
I am having problems with the driver's side sports seat in my 98. Looks like the fuses are good but the bolsters and the lumbar funcitons are not working. The power seat adjustments are working fine just not the lumbar and the bolsters. They work fine on the passenger seat. Wonder if it could be contacts need cleaning. If so can I take my seat out and clean the switches contacts? I thought I heard a faint motor noise but not sure.
Thank you,
Bill
Old Apr 23, 2006 | 11:19 PM
Oldvetter's Avatar
Oldvetter
Just saw your post. I emailed you a troubleshooting guide for Driver's lumbar not working.
Good Luck !
Old Apr 23, 2006 | 11:53 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Both the lumbar and bolsters are operated with air. I would suggest if you're hearing a motor noise the compressor is probably alright. I'd check the hoses for leaks. You'll have to take the seat apart which is not difficult (see the VetteEssentials site for directions). There are small rubber hoses running all over the back of the seat and one is probably loose or leaking.
Edit: while you've got the back apart cover the bolster with indoor/outdoor carpet like VE shows so it doesn't poke thru.
Old Apr 26, 2006 | 01:11 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Old May 8, 2006 | 09:55 PM
SMRSVET's Avatar
SMRSVET
8th Gear
Default Same Problem
Hey Oldvetter, i'm having the same problem too, mind sending that troubleshooting guide my way too?
Adam
Old May 8, 2006 | 11:13 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Good Luck !
just discovered on StuzVette the air will go in...
...but it just wont exhale...
do your instructions fix that too...?
To Sports Seats Electrical Problem
