Partnumber needed windowfelt?
Old Apr 24, 2006 | 11:54 AM
Erik88vette's Avatar
Erik88vette
Default Partnumber needed windowfelt?
Hi guys,I'm in need of the partnumber of a windowfelt....I think that is what the $&&^%^@$$#$ thing is called.Both my windows are getting scratched by some kind of black thingie inside my door.It's kinda like a weatherstrip but it's actually not.The window slides against this thing when it's going up and down.Doe sanybody know the name of that thing AND has a partnumber??
Greetz Erik.
Old Apr 24, 2006 | 12:06 PM
Diamond's Avatar
Diamond
Cruise-In II Veteran
Cruise-In III Veteran
I assume you are looking for the door belt weatherstrip. I will guess you have a coupe, different #'s for the coupe, convert and hardtop. Coupe #, driver side is 10447040. 01-04 that number changes to a 10313421. Hope that helps you.
Old Apr 24, 2006 | 12:11 PM
LETHL_C6's Avatar
LETHL_C6
Good topic.... I was just thinking about the same thing this weekend. I would also like to know the PN's for the outer window seals if anyone has them stashed. Would be nice to change the inner and outer at the same time to be done with them.
Old Apr 24, 2006 | 12:33 PM
Erik88vette
I talked with someone on the phone just now and he said they call it:anti rattle cushion P/N 10447045...????Can someone confirm this,it's NOT the outer door to window seal....it's almost as long but it is screwed inside the door so the window slides against it,going up and coming down.It's wrapped in a kind off soft cloth material.Hope this helps.
Greetz Erik.
Old Apr 24, 2006 | 12:40 PM
Diamond's Avatar
Diamond
Erik, I would trust his part #. I dont show the inner, I believe they come with the trim panel assy. ( which you dont need ) Part number on outer for the Z06 is #10313427 left, right is 10313426.
Old Apr 24, 2006 | 01:21 PM
Erik88vette
Oke,I have a '99 coupe and need the right as well as the left side.
Can you give me both the partnumbers??
(driverside=10447040...pass side=........41?)
Thanks a million
Greetz Erik.
Old Apr 24, 2006 | 01:56 PM
Diamond's Avatar
Diamond
Erik, here are the numbers for the 99. I had a 97 coupe listed. Here you go, outer belt weatherstrip, 98-00. Left# is 10313421, right is 10447040.
Old Apr 24, 2006 | 05:42 PM
Erik88vette
Will check it out tommorow......
Greetz Erik.
To Partnumber needed windowfelt?
