Tire Pressure Mon System
Old Apr 24, 2006 | 03:19 PM
dwalker011's Avatar
dwalker011
Default Tire Pressure Mon System
Do all C5's besides z06's come with tire pressure sensors? Is there a way to tell whether they do from looking at wheels from the outside?
Old Apr 24, 2006 | 04:20 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Yes - the TPM was standard on all C5's except for the Z06's. And no - there's no visual clue. The TPM is the valve stem, the actual sensor is inside the wheel.
This is the old style ('97 - '00)
This is the newer style ('01 - '04)
They are not interchangeable in either direction.
Old Apr 24, 2006 | 05:59 PM
Evil-Twin's Avatar
Evil-Twin
Yes it is very easy to tell if you have a valve stem or sensors...
A valve stem is seated to the rim via a rubber grommet, it is pulled into place from outside the rim and is help in place by this rubber grommet..
Tire pressure sensors are held in place by a nut that can be seen at the base of the valve stem from the outside of the wheel.
Old Apr 24, 2006 | 06:16 PM
blacksedan87
I forgot about that.....:o
Old Apr 24, 2006 | 09:12 PM
Evil-Twin's Avatar
Evil-Twin
I feel so bad now
I sowwwry
Old Apr 25, 2006 | 02:14 AM
dwalker011's Avatar
dwalker011
I feel so bad now
I sowwwry
Don't worry about it. How do these sensors actually communicate with the ECM. Is it a magnetic pick up or some kind of radio frequency? Thanks for the help guys.
Old Apr 25, 2006 | 02:23 AM
dataporter's Avatar
dataporter
Radio Frequency
The antenna is the same for the keyless remote entry.
The antenna is mounted above the drivers side rear wheel in the car behind the trim (carpet).
Dave
To Tire Pressure Mon System
