ridiculously easy noob question
Old Apr 24, 2006 | 09:47 PM
StoplightWarrior's Avatar
StoplightWarrior
Default ridiculously easy noob question
I was under the impression that I have the stock suspension setup...f45 or something...
but then I got to thinking, maybe I have the z51
How can I tell for sure? Is there a designation in the glove box for it, like with the axle?
Old Apr 24, 2006 | 10:03 PM
shakainc's Avatar
shakainc
I believe it's FE3.
Old Apr 24, 2006 | 10:53 PM
George8211's Avatar
George8211
Originally Posted by shakainc
I believe it's FE3.
Old Apr 24, 2006 | 10:57 PM
GrayC5's Avatar
GrayC5
Look for the Service Parts Identification (RPO) Label. For later model years, it will be on the inside of the glove box lid. For earlier model years, it will be on the underneath side of one of the rear compartment (left side I believe) lids.
The following link has one of the most comprehensive lists of C5 RPO codes that I've found:
Chevrolet Corvette C5 RPO Code List
Following are the RPO Codes for the various C5 suspensions:
F45 Chassis, Selective Real Time Damping
F55 Continuously Variable Electronic Real Time Damping Suspension by Delphi (Often referred to as Magnetic Selective Ride Control)
FE1 Base Suspension
FE3 Suspension System, Sport (part of Z51)
FE4 Suspension System, Z06
Technically RPO Z51 is the Performance Handling Package. It consists of the RPO FE3 Sport Suspension and a power steering cooler. If your car has the Z51 option, you RPO label should show both the FE3 and Z51 RPO codes.
Hope this helps.
Old Apr 25, 2006 | 12:06 AM
StoplightWarrior
thanks guys, big help!
Old Apr 25, 2006 | 01:29 AM
countslav's Avatar
countslav
Open hood,...look for power steering cooler....
Old Apr 25, 2006 | 01:40 AM
StoplightWarrior
and then?
Old Apr 25, 2006 | 01:48 AM
countslav's Avatar
countslav
If you can see a cooler,....you have the Z51 option...
Old Apr 25, 2006 | 06:21 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if it's there you got it, if it isn't you don't.
Old Apr 25, 2006 | 09:42 AM
George8211's Avatar
George8211
Z51...
Powersteering cooler (about 12 long down low)
3.15 Rear Gears
Larger Front and Rear Sway Bars
It's probably one of the best value options you could have
gotten with a new purchase.
Old Apr 25, 2006 | 09:46 AM
sailohio's Avatar
sailohio
What years did they begin to offer the power steering cooler on the Z51 package?
Old Apr 25, 2006 | 03:39 PM
StoplightWarrior
I checked...FE1.
weak.
what can I do to simply improve performance a bit (i'm bone stock in that department, other than the free lowering mod)
Old Apr 25, 2006 | 03:52 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Originally Posted by StoplightWarrior
What can I do to simply improve performance a bit (I'm bone stock in that department, other than the free lowering mod)
This in an interesting question: what can be done to inexpensively upgrade the stock suspension on a C5?
Old Apr 25, 2006 | 04:08 PM
StoplightWarrior
exactly.
I mean, throw some sway bars and shocks on there for like $700, but will that make a noticeable improvement, with little or no detriment to daily driveability?
experts need to chime in
Old Apr 25, 2006 | 04:19 PM
acrace's Avatar
acrace
What do you want to upgrade? Not being sarcastic, but different people have different needs.
If you want to improve the grip, my recommendation would first of all check the alignment and optimize it for the type of driving you do (taking into account how much corner carving you do versus highway miles).
If you want to improve body motion control, I would go for shocks.
Tires would also make a huge difference, especially if the car still has the original equipment run-flats.
Old Apr 25, 2006 | 04:29 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
(even though I've stayed with the run-flats)
Car & Driver compared all the then-current Corvette suspensions back in September, 2003. I believe this article is still relevant:
http://www.caranddriver.com/features...disbelief.html
Old Apr 25, 2006 | 05:45 PM
ytwokc5's Avatar
ytwokc5
I remember reading that article... thanks for refreshing us... good info.
From the article:
"The first conclusion that leaps out of the test-results box is that switching to Z06 tires almost brings the base and MSRC cars up to the performance level of the stock Z51, and the F1 Supercar tires bring the Z51 to within a nose of the Z06 in the tighter maneuvers that negate the Z06's big power advantage. On average, the tires alone improve skidpad grip by 0.04 g, lane-change performance by 1.7 mph, and autocross and handling circuit times by 1.3 and 1.8 seconds."
Old Apr 25, 2006 | 07:38 PM
StoplightWarrior
I gotta ditch these runflats
Old Apr 25, 2006 | 07:44 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Get Hotchkis front and rear sways with their end links and also install 04 ZO6 shocks.
Worth every penny in your case.
To ridiculously easy noob question
