C5 issues at higher mileage?
Old Apr 25, 2006 | 04:11 PM
txjeep's Avatar
txjeep
Default C5 issues at higher mileage?
Howdy C5 owners. I need your help. I found a 2002 C5 with 75k on it that I have taken a liking to. It appears to be well maintained, but the higher mileage is concerning me a bit.
What kind of problems are typical for C5s with this kind of mileage?
What should I expect over the next 30k miles?
Any input is appreciated!
Old Apr 25, 2006 | 04:18 PM
2ndVette's Avatar
2ndVette
I don't know how you could get any meaningful response to a question like that. The correct answer is who knows! If I were to venture an opinion, 75K should not be viewed as high mileage for any car. It would be different if you were buying a car with only 12K mile warranties that we are all doing prior to the 80s. Then there is subjective opinions as to what high mileage represents. Pristine? Average? What is your mechanical ability? Would you prefer a car that you just put gas in and drive? The questions are endless and you are the only one that can answer them.
Old Apr 25, 2006 | 04:42 PM
txjeep's Avatar
txjeep
The second question is admittedly subjective, the first is not. Most cars have certain issues that are common, and the list usually grows with higher mileage.
I am looking at this as my daily driver. Considering that it has 75k miles on it, I am a little concerned about reliability. I put about 10k a year on my vehicles and would probably keep this one at least 2-3 years, which puts me right at 100k miles. I am mechanically capable, but do not have the time for repairs these days (kids, work, life, etc.).
Does anyone here have 60k+ miles on their C5? If so, would you mind sharing whether or not your C5 has been what you consider reliable?
Thanks!
Old Apr 25, 2006 | 05:17 PM
TSLDave's Avatar
TSLDave
1998 coupe with 73K miles. The ONLY problem I've had is the battery. Change the oil and service it regulary and it will last at LEAST as well as any other car. I've also got two other cars ( not vettes) with 200+K and have had 3 others that I've sold at 200+K. preventive maintenance!!!!!! Abuse it, and you take your chances
Old Apr 25, 2006 | 05:53 PM
txjeep's Avatar
txjeep
Thanks Dave. Good info.
It looks like no news is good news in this case.
Jason
Old Apr 25, 2006 | 06:58 PM
gkc501's Avatar
gkc501
’01 with 72,000 miles. No problems at all the last 20,000 miles or so. All the problems I had were factory defects the first few years – all were fixed under warranty.
My vette is my daily driver, and I consider it to be a very reliable one.
Old Apr 25, 2006 | 07:18 PM
mcarota's Avatar
mcarota
Just sold my 98 with 84k miles on it. The things that I did were: battery, belts, plugs, wires, tires, headlight swtich, and brakes. Other than regular maintenance items, I had no problems with the car, it ran strong!!!!
Old Apr 25, 2006 | 07:21 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
i'm at 132,000 miles. Most of my problems i caused myself...although, the a/c failed and so did the starter...big deal.
Old Apr 25, 2006 | 10:13 PM
rws.1's Avatar
rws.1
78K miles here
brakes, tires, battery
fluids
Nothing else mileage related
Old Apr 25, 2006 | 10:33 PM
Joevette99's Avatar
Joevette99
Default 79,000 on Mine
I have a '99 Targa 6sp. I have had it since 5k. hear is the history.
1. Front Brakes/Rotors 65k
2. Oil pressure gauge sending unit 45k(very common)
3. Steering column locked up (3 times) everyone has this problem and there is a recall to fix.
4. Replace muffler 73k just because I wanted a change in sound.
5. Changed clutch with Z06 one at 75k and all fluids(trans, rear).
6. B&B shorties, Blackwing air filter, Lingenfelter TB and Z06 intake manifold at 75k.
Car runs very strong. Does not burn oil. Car is so fast traction control pops on in first gear at 4500rpm's..makin some horsepower.
I am contemplating H/C swap because car is in such good shape and has been very trouble free.
On the other hand, the difference between a 40k and 75k car is only a few grand. Go for the less mileage car if you can afford it.
Good Luck
Car runs strong as ever.
Old Apr 26, 2006 | 12:52 AM
99vertnbm's Avatar
99vertnbm
84,000 miles. MN6
1 set of tires
1 set of brake pads
28 oil changes.
Asjust parking brake shoes once.
1 bumper cover repaint-rock chips
1 serpentine belt
2 sets of floor mats
No other bolts turned
Old Apr 26, 2006 | 07:55 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
02 91K
oil pressure sensor
O2 sensor(driver side)
Front wheel bearings
all after warranty ran out.
Old Apr 26, 2006 | 08:13 AM
txjeep's Avatar
txjeep
Thanks everyone. That's exactly what I was looking for. Sounds like GM did a good job on the C5.
Old Apr 26, 2006 | 01:36 PM
fdxpilot's Avatar
fdxpilot
They did, at that. If you read the forum(s) a lot, you can begin to think C5s have lots of problems. But consider how many were made, and that a lot of forum cars are modified, which can bring up reliability issues. Also, people rarely post that they drove their car the last few days and had no problems. There are a few problem areas, as mentioned. Lately, it seems like a rash of EBTCM (the electronic part of the ABS/TC/AH control module) failures has popped up. I had one, as well as a headlight motor in 30K miles. Otherwise, works good, lasts long, goes fast!!
Old Apr 26, 2006 | 01:47 PM
wolverdick's Avatar
wolverdick
St. Jude Donor '04-'05-'06-'10
Mine is only at 62k but has seen a lot of cross country driving.
Havent had any issues with the oil pressure sensor but heres my list of fixes/mods.
Blown Catalytic converters once, decide to use that as an excuse to replace headers, install high flow cats, x-pipe and new magnaflow muffler.
The heasdlight gear issue. Replaced my gears with the brass ones, no more winking.
Also have replaced the front under spoiler. Scraped to death so many times, i finally just got a new one.
Other than that, this car is a dream to drive and own.
Treat her well, and shell perform like nothing you can imagine.
Old Apr 26, 2006 | 02:48 PM
Rapidity's Avatar
Rapidity
01 w/ ~55k on it... oil pressure sensor just went out and just yesterday i broke the passanger side sun visor. lol
Old Apr 26, 2006 | 02:55 PM
chargedsol's Avatar
chargedsol
98 with 90k. fuel pressure issue was fixed earlier, still happens once in a while.
some electrical gremlins
other then that, its still running strong, i even have the original clutch in still!!
To C5 issues at higher mileage?
Old Apr 26, 2006 | 02:58 PM
MattB's Avatar
MattB
Bought mine last year at 74k and its now at about 86k, it is a 2000 coupe. No real problems; Oil pressure sensor has never worked for me, and my AC compressor belt disappeared sometime in the last two weeks. Not sure if that means I have a problem with the compressor or not, most likely I did something to it. :o
I just started taking it to the track and it is a beast.
Old Apr 26, 2006 | 03:09 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
04 about to turn 60K miles....no issues
Old Apr 26, 2006 | 03:12 PM
Disco Stu's Avatar
Disco Stu
2002 coupe, 65k miles.
tires. battery (x2 under warranty). ABS sensor under warranty. just replaced 4 rotors and pads over lunch.
