Drag radial choices
Old Apr 25, 2006 | 04:52 PM
kevyn's Avatar
kevyn
Default Drag radial choices
I have run Nittos on my last couple cars but now that I have an 18" rear tire, they're not an option. They don't come in 18".
I went to my local performance tire store and checked out my options. I seen the 18" BFGs but I don't really want that particular tire.
I have an idea and I'm curious if it's a viable option. They offer a set of 17" x 9.5" thin spoke replicas for 200 ea. (or I could look for a used set).
Moving to a 17 on the back would give me a wide range of drag radial options. Nitto, BFG, Hoosier & MT.
Would there be a problem running a 17 in the back? I assume the brake calipers would clear. I'm guessing the offset would be OK but what about the stance? Would it look OK?
Has anyone has done this? If so, could you post a pic so I have an idea what it would look like?
If the 17s are not a good idea, what are people with 18's using for light track duty?
thx
Old Apr 25, 2006 | 05:10 PM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
Get the 17's. Tires are way too expensive, and can't get the M/T ET street radials.
Old Apr 25, 2006 | 05:44 PM
ls1vette97's Avatar
ls1vette97
I'm running the Nitto 555R drag radial 305-35-18.... What size is your rear rim?
EDIT: Mickey thompson is coming out with the et streets in 18" wheel size....
Old Apr 25, 2006 | 06:15 PM
kevyn's Avatar
kevyn
I have stock 2002 wheels. I'm guessing 18" x 9.5?
I waited a year for the 275 17 MTs after they were announced. I'll believe the 18s when I actually see them
Old Apr 25, 2006 | 07:25 PM
ls1vette97's Avatar
ls1vette97
I believe it is possible to fit the 305's on a stock rear.... They will have one hell of a time mounting them, but I've seen people running the 295's on stock rims (Nitto's run narrow compared to other tires). My guess is they would work....
Old Apr 25, 2006 | 08:00 PM
kevyn's Avatar
kevyn
They offered to sell me the 305's but in my head I was picturing a tire with a rounded contact patch and bulging sidewalls.
How do the 305's fit on your car? Is it a 9.5"width rim?
Old Apr 27, 2006 | 09:19 PM
kevyn's Avatar
kevyn
Has anyone seen or run these?
I think they're new.
To Drag radial choices
