WARNING! learn from my mistake!
Old Apr 25, 2006 | 06:40 PM
KODAK's Avatar
KODAK
Default WARNING! learn from my mistake!
Ok...this is simple. Please keep all trash out of your lower windshield erea! You know the place that trash loves to hang out when you open your hood.I do a ok job of that myself but what happened to me was the rubber pipe thst allows water to escape from under the car had clogged up and water came into my car and fried my BCM, Body Control Module. This is very easy to check.
1) Remove wipers
2) remove plastic cover
3) check for trash on the drivers side where you connect your wiper. There is a rubber tube that is under your wiper bolt.
4) save $500.25 for a new BCM!
Mech at dealership told me that there was two rubber tubes. pas and driver side. I could not get to the one on the Pas side. Is there even one there??????????? I'm getting two stories. It is a 1999 coupe.
Old Apr 25, 2006 | 06:54 PM
Darion's Avatar
Darion
Thanks for the info and sorry you had to find out the hard way.
Old Apr 25, 2006 | 07:17 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
WOW, I never new this had to be cleaned, thanks for posting..
Bob
Old Apr 25, 2006 | 07:24 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
You can reach these without removing anything.
Old Apr 25, 2006 | 07:28 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
there are 3 on the drivers side and 2 on the pass side. See Bill Curlee's Sticky in the C5 Tech section for details.
As Stangkiller said, you do not have to remove anything.
Old Apr 25, 2006 | 07:33 PM
shakainc's Avatar
shakainc
Yep. I knew about the three on the driver's side but found out about the others at EG's house. Mine were full of leaves.
Old Apr 25, 2006 | 07:35 PM
5.0_CJ's Avatar
5.0_CJ
Welcome to my world! Proudly paving the way so others are not so unfortunate!
Old Apr 25, 2006 | 07:36 PM
1 COOL 99's Avatar
1 COOL 99
I believe they are actualy called utters and a somewhat easy way to get to them is to take off your front tire and then remove about a half dozen screws that hold on the wheel well liner. You will be able to reach up and open the bottom of the "udder" to let out any debris that is stuck.
Old Apr 25, 2006 | 07:37 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Thanks for the heads-up and sorry about your problem..
Old Apr 27, 2006 | 04:18 PM
KODAK's Avatar
KODAK
Well damn! Here I go again! LESS THAN 24 HOURS LATER MY CAR DIES ONCE AGAIN! 3 TOWS IN 4 DAYS! This is getting old. Mech called me today and said it needed yet another BCM change! My brand new one was full of water...again. He sad he cleaned everything out good this time. Please make sure your lines are not full of trash!
Old Apr 27, 2006 | 04:19 PM
0EG@EnglandGreen
Supporting Tuner
Get a new tech. Read this.
http://forums.corvetteforum.com/show....php?t=1246715
Old Apr 27, 2006 | 05:11 PM
Thanks for the reminder.
Old Apr 27, 2006 | 10:07 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Ok so tell us how!
Old Apr 27, 2006 | 10:11 PM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
Old Apr 27, 2006 | 10:30 PM
0EG@EnglandGreen
Supporting Tuner
Originally Posted by 87bob
Ok so tell us how!
Read this.
Old Apr 28, 2006 | 12:49 AM
TA8088's Avatar
TA8088
Good to know. I'll have to check mine.
Old Apr 28, 2006 | 01:17 AM
edensknight's Avatar
edensknight
Great link, EG!
Old Apr 28, 2006 | 06:40 AM
Dark-Knight's Avatar
Dark-Knight
Ouch!
Thanks for the tips!
Old Apr 28, 2006 | 09:06 AM
0EG@EnglandGreen
Supporting Tuner
Originally Posted by edensknight
Great link, EG!
Bill (Curlee) has had that Sticky up in the C5 Tech section for quite some time. I just wish more members would visit Tech - it would save them a huge amount of heartache - and a large amount of money.
To WARNING! learn from my mistake!
