Advice on New Brakes
Old Apr 25, 2006 | 10:19 PM
Un4given's Avatar
Un4given
Default Advice on New Brakes
I'm ready for new brakes on my '02 C5. I only drive in on the street so I don't need high performance. I have read a few posts here through the search feature but I'm still not sure what I need.
I'm thinking of ordering the GM slotted and drilled rotors and ceramic front and rear pads from Gmpartsdirect. Is this a good setup or is there something better for a comparable price? Is there a better place to order?
Also, is this a DIY? What's involved in doing this? I am mechanically inclined but I don't want to risk my families safety if this should be left to a professional.
Thanks for any help.
Old Apr 25, 2006 | 10:27 PM
Oldvetter's Avatar
Oldvetter
Delco Ceramic Brake pads are great, very little dusting and white dust at that.
Never replaced rotors, you need a breaker bar. Also either buy new rotor bolts or clean and reapply locktite blue on old ones.
Old Apr 25, 2006 | 10:36 PM
RTSVET's Avatar
RTSVET
Make sure you get zink coated rotors so they wont rust and i like the hawk hps pads.
I have sportsbrakes brembro drilled slotted zink coated rotors with hawk hps pad and i think they are great low dust and great stopping power.
Old Apr 25, 2006 | 11:10 PM
rws.1's Avatar
rws.1
The AC/Delco durastop ceramics are great for low dust and give acceptable stopping power.
the AC/Delco slotted/drilled rotors are NOT zinc coated..... spend the extra and buy sportbrakes.
www.sportbrakes.com
Tell Raz you are form the forum and you will get free delivery...
Should cost you under $275 for the 4 corners
Old Apr 26, 2006 | 10:33 AM
BananaVett's Avatar
BananaVett
What about NAPA rotor's and pads... how do they compair with sportbreaks rotors and pads in price, quality, and dust?
Also, can anyone tell me how cheap are new rotor bolts instead of trying to reuse the old ones?
Old Apr 26, 2006 | 01:05 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Unless you are familiar with brakes and their components(like ABS), I'd leave it up to a professional(like myself). I've seen way too many DIY'ers screw them up and come into our shop, horrified on how they made it without killing someone.
Old Apr 26, 2006 | 10:10 PM
Un4given's Avatar
Un4given
That's why I wanted to check. I found some instruction someone posted and it seems really easy but Murphy always manages to show up and cause things to happen.
My dealer said if I brought him the rotors and pads they would install install them for $99 an axle.
Old Apr 26, 2006 | 11:33 PM
jrose7004's Avatar
jrose7004
I went with Raybestos Quiet Stops and the Sport Brake drilled and slotted rotors.
Old Apr 27, 2006 | 11:24 PM
Un4given's Avatar
Un4given
I've seen some very good reviews and comments on Raybestos Quiet Stops. I think I will be picking up a set of these. I've gone to sportbrakes website but none of the pictures work so I can't see what I'm buying. I assume rws.1 picture is the drilled and slotted ones but I'd like to see what the dimple and slotted ones look like.
Anyone know the best place to order Raybestos Quiet Stops?
Old Apr 28, 2006 | 08:43 AM
9secondflat's Avatar
9secondflat
i have had the gm slotted drilled and ceramic pads on my car for one week. the rotors have already started to rust (not the part where the pad goes on but the hub area) and as for the ceramic pads, i dont care for them, yes they are quiet but their stopping ability compared to the factory oem pads stink. i will be removing my pads in the next month and offering them for free to a list member if they want them.
Old Apr 28, 2006 | 10:12 AM
rws.1's Avatar
rws.1
Un4given...
You are correct mine are Drilled/Slotted.
I tried the sportbrakes site as well... same problem with pics...
Old Apr 28, 2006 | 11:32 AM
Uncle John's Avatar
Uncle John
Regardless of what was mentioned earlier, there is no such thing as rotor bolts. There are lug nuts, caliper bolts and caliper mounting bracket bolts. Most people, myself included, clean the original bolts and reuse them after applying Loctite or any comparable thread locker.
Old Apr 28, 2006 | 04:38 PM
jman1's Avatar
jman1
i've got the rotorpros set up...
Old May 18, 2006 | 12:07 PM
YO-EL's Avatar
YO-EL
How do you like em?
Old May 18, 2006 | 12:32 PM
Ducman69's Avatar
Ducman69
Although not sure about the HPS, I assume those are just a little milder than the HP+s?
Old May 18, 2006 | 12:59 PM
I'm running the Hawk HPS brake pads - so far they have performed very well. As far as the rotors go, the Sportbrakes are a good product and are moderately priced.
To Advice on New Brakes
