fuel gauge
Old Apr 25, 2006 | 10:51 PM
doug doo wop's Avatar
doug doo wop
Default fuel gauge
the other day my gas gauge dropped to empty but it came back on the next day;I'm sure it will happen again. If it stays that way and needs repair, what is involved and does extended warranty cover this? Thanks Doug
Old Apr 25, 2006 | 11:04 PM
rws.1's Avatar
rws.1
There are a number of possibilities...
1. a fouled fuel sending unit.... add a good fule system cleaner like Techron or Chemtool B-12
and switch to a top tier gasoline www.toptiergas.com
2. corroded ground for the sending unit
3. faulty sending unit
Try the fuel system cleaner and switch gasolines
Old Apr 25, 2006 | 11:38 PM
GrayC5's Avatar
GrayC5
http://forums.corvetteforum.com/show....php?t=1369756
http://forums.corvetteforum.com/show....php?t=1374864
Various extended warranties differ on what they cover. You would just have to check with your warranty company to see what they cover.
Good luck.
Old Apr 26, 2006 | 12:10 AM
Tom337's Avatar
Tom337
Techron gas treatment worked for me.
Old Apr 26, 2006 | 12:27 AM
99vertnbm's Avatar
99vertnbm
Chevron Supreme, it has techron. Cured my faulty gauge.
Old Apr 26, 2006 | 12:35 AM
striper's Avatar
striper
As soon as this happened to me I started putting in Techron. Cured the problem right away. Keep a few bottles at home, it is easier than having your gas tanks removed.
Old Apr 26, 2006 | 12:43 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Answers are just 2 threads down...
Old Apr 26, 2006 | 01:19 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
I'm on the Chevron bandwagon. I've tried several times going to a cheaper gas and the problem comes back within a couple tanks. Now the only time I use anything else is if Chevron isn't available.
Old Apr 26, 2006 | 06:56 AM
Try running a bottle or two of Techron through the tank. Seems to work well in helping cure the erratic fuel gauge problem.
Old Apr 26, 2006 | 03:56 PM
doug doo wop
Thanks for the great wisdom of the forum and I will try the Techron. It has only happened once. I don't recall any Chevron stations around.
Old Apr 26, 2006 | 04:11 PM
edensknight's Avatar
edensknight
Originally Posted by EnglandGreen
I, too, have had to replace the fuel sending unit assembly, AND, have had the proper "reflashing" to the PCM. And, I have found the least problems (continued erratic fuel gauge readings) when imposing a strict diet of only Chevron Premium with regular Techron II maintenance.
Old Apr 26, 2006 | 06:40 PM
BELVIN20's Avatar
BELVIN20
Extended GM Warranty replaced my sending units and all has been well for the past 2yrs.
Old Apr 26, 2006 | 06:45 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Where exactly is the fuel sending unit?
Old Apr 26, 2006 | 06:51 PM
0EG@EnglandGreen
Supporting Tuner
Driver's side gas tank - http://forums.corvetteforum.com/show....php?t=1369756
Old Apr 26, 2006 | 07:53 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Trust me if it happened once it will happen again. Get yourself a couple bottles of Techron from the auto parts store.
Old Apr 26, 2006 | 09:32 PM
C5Jim's Avatar
C5Jim
Last August at Corvettes at Carlisle, I got a chance to ask one of the GM engineers about the gas gage issue. He said the problem was excessive sulfur in some fuels that was leaving a film on the sending units, which in turn would cause erractic failure.
The GM engineer reccomended (2) bottles of Techron. I did what he suggested and hav enot had a problem since.
BTW, Costco sells Techron 4-pack for about $10.
Good luck.
To fuel gauge
