Flush mount tail lights?
Old Apr 26, 2006 | 01:38 PM
rkhegler's Avatar
rkhegler
Default Flush mount tail lights?
Been thinking about doing this on my 99 FRC. Any opinions or comments on install?
Old Apr 26, 2006 | 01:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It keeps the water and dirt from sitting on the ledge. I do not like them myself. I like the recessed look.
Old Apr 26, 2006 | 02:40 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I bought the kit from West Coast Corvettes and I like it. It's a quick easy mod, and best of all - if you don't like it after it's done, it's easy enough to reverse it.
Old Apr 26, 2006 | 02:43 PM
BarneePhife's Avatar
BarneePhife
St. Jude Donor '07
See this thread...
http://forums.corvetteforum.com/show....php?t=1373344
Old Apr 26, 2006 | 02:48 PM
CTRFLDR's Avatar
CTRFLDR
I'll be modifying mine this weekend, bought everything I need from Home Depot. Have seen a lot of pictures and they all look great, if I don't like it on my 2004 C5 then I'll simply reverse the mod. I use a H2O-less cleaner so the puddling and dripping isn't an issue for me.
Old Apr 26, 2006 | 02:59 PM
screw991le's Avatar
screw991le
The weather stripping is a good idea, but I just can't get use to the look.
Old Apr 26, 2006 | 03:15 PM
BarneePhife
St. Jude Donor '07
The flush-mounted look? Or the look of the weather stripping?
Southern Car Parts sells a weather stripping kit that looks very sharp. I was just too cheap-o to use it myself. Actually, I'm not sure that it would work with flush mounted lights because I think there may be a slightly larger gap between the light assembly and the cavity when the light is out at the edge like that.
Old Apr 26, 2006 | 04:57 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
I bought my kit from LAPD (I think). Install was very easy and I think it looks great.
Old Apr 26, 2006 | 05:06 PM
rcs128's Avatar
rcs128
it's cheap, easy, helps keep the lights area cleaner, and looks good. And you can reverse it in about 10 minutes if you ever change your mind. Go for it!
Old Apr 26, 2006 | 08:01 PM
edensknight's Avatar
edensknight
Old Apr 26, 2006 | 08:07 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Here is the look...
Peace
Willfulone
__________________
..................Click for
Old Apr 26, 2006 | 09:16 PM
rkhegler's Avatar
rkhegler
Originally Posted by Willfulone
Here is the look...
Peace
Willfulone
Thanks for all the info and the pics. I think I will give this a try.
Old Apr 26, 2006 | 09:20 PM
JJWVETTE's Avatar
JJWVETTE
Do it yourself Got all the parts needed at Home Depot
Old Apr 27, 2006 | 03:11 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Originally Posted by BarneePhife
try as I might, the stores in our area do not carry the seal shown in this thread..anyone fix me up?? BTW the taillight seals mentioned work fine with the flushmount kit.
Old Apr 27, 2006 | 05:26 PM
OUR97's Avatar
OUR97
I did mine with the spacers from Home Depot and the Half-round weatherstripping. Couldn't find black so I got grey and a black sharpie. A couple passes with the sharpie and looks like a million bux. I think it looks better than stock and easier to clean. If you have a black car you know what I mean.
Old Apr 27, 2006 | 06:24 PM
hawk1's Avatar
hawk1
Old Apr 27, 2006 | 06:36 PM
CCA Corvette Parts
Grumpy, shoot me a PM with your address and I'll send you some...
Peace
Willfulone
To Flush mount tail lights?
Old Apr 28, 2006 | 07:36 AM
Jims99frc's Avatar
Jims99frc
I just did mine on Thursday , I also installed the "halo" LED lights . These lights are so bright , and flush mounted they look great . I purchased both the lights and flush kit from an east coast corvette shop .
Here is a close up .
I'm happy ..
Old Apr 28, 2006 | 08:01 AM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I did this one DIY style ... I like it and I'll keep it.
On to the next mod ... whatever that will be.
Old Apr 28, 2006 | 09:21 AM
DRJJ1's Avatar
DRJJ1
Default Waste Of Time
IT IS A WASTE TO CHANGE TO THE LIGHTING IN THE REAR,,YOU LOSE MONEY,,,YOU CHANGE STOCK AND IT LOOKS FUNNY,,THE AMOUNT OF DIRT AND WATER IN THE LIGHTS IS MINIMAL AND IT CLEANED EASY YOU DON T KNOW WHAT TO CHANGE NEXT BUT KEEP DOING IT AND YOU WILL LOSE MORE MONEY ON YOUR CAR WHEN THE DAY COMES TO SELL IT,,,,,,YOU BEEN WARNED
STAY ORIGINAL AND STAY HOTTTTTTTTTTTT
