[Z06] Car wont start...
Old Apr 27, 2006 | 03:05 PM
Nulltime's Avatar
Nulltime
Default Car wont start...
I went out to the car this morning and it would not start. Partial power to the car : Headlights work, no radio, no other lights, no remote locks. I gave it a couple hours and makes a loud clicking sound when it tries to start (better than the nothing i got earlier) I'm thinking a drain killed the battery. Is there anything special I need to do to jump start it ? Or that I need to be concerned about?
Thanks in advance.
Edit : The real oddball thing is the headlights still work...
Old Apr 27, 2006 | 03:16 PM
Ranger's Avatar
Ranger
Probably the battery died. When they go, it's often without warning.
If you're still on the OEM battery, you might want to start reading up on the Optima Red Top. Many members switched to that one and are happy with it.
Ranger
Old Apr 27, 2006 | 04:37 PM
Harlock's Avatar
Harlock
Very similar thing happened to me.
. .and yup . .it was the battery. Get a optima red top and you are as good as new .. hope you remember your radio lock code
Old Apr 27, 2006 | 04:57 PM
DPG's Avatar
DPG
St. Jude Donor '06
battery is the answer. Your lucky. others have gotten much weirder problems all from a dying battery.
Old Apr 27, 2006 | 05:44 PM
Nulltime's Avatar
Nulltime
Radio lock codes? Got it used, I have no idea what those are. Heh I didn't even know it had them. How do I find that information out?
Edit : Also isn't there some kind of retraining process for the computer when the battery goes dead? Or rather is there a method of driving you need to adhear to while it relearns?
Old Apr 27, 2006 | 06:25 PM
e-hodges's Avatar
e-hodges
St. Jude Donor '06-'09
you should be good, just put in a new battery, Ive done it twice and never had to reprogram anything.
Old Apr 27, 2006 | 06:39 PM
Nulltime's Avatar
Nulltime
Awesome, thanks all I appreciate the help
Old Apr 27, 2006 | 07:05 PM
Andy64's Avatar
Andy64
As far as the Radio lock codes go ... there is a posting in the Tech Tips Section on how to get around it:
https://www.corvetteforum.com/techti...=164&TopicID=1
As far as the driving afterwards, I believe there is a relearning process that must occur and you probably should drive "normal" for about 40 minutes or so ... I'm sure others have a better handle on that aspect. Good luck.
To Car wont start...
