Check engine lite on...need help
Old Apr 27, 2006 | 10:17 PM
mcmtac14's Avatar
mcmtac14
Default Check engine lite on...need help
Well my 2002 that I just bought in December has the check enine light on! Here is what it is doing:
1. Started it this evening and it was running rough.
2. After 3 minutes of normal driving the check engine light came on
3. My gas milage average went from 19.8 to 12.6
My car has 13500 miles, recent Mobile 1 oil change, driven every day since I bought it. When I got the car it had 7500 well maintained miles.
Any ideas before I take it to the GM store???
Many thanks, can't sleep waiting for 7:30 tomorrow when the service dept. opens!
mcmtac14
Old Apr 27, 2006 | 10:22 PM
Denney's Avatar
Denney
mcmtac14
My guess would be the fuel pressure regulator crapped out on you... To know for sure you should get a code scanner and check the code before you drop it off...
Old Apr 27, 2006 | 10:30 PM
VetteNoob's Avatar
VetteNoob
What code did it throw? Check here for how to pull codes and what code it threw. H codes are history codes and not what has happened recently. C codes are current codes that have recently occurred.
http://www.stengel.net/diccodes.htm
Old Apr 27, 2006 | 10:37 PM
WWK888's Avatar
WWK888
Why do you need a code scanner, just check the codes with the DIC.
Old Apr 27, 2006 | 10:49 PM
jdmvette's Avatar
jdmvette
Night Owl for life
check to see if a spark plug wire came loose. serious. it happened to me today.
Old Apr 27, 2006 | 10:54 PM
mcmtac14's Avatar
mcmtac14
Default Check engine ... help
Many thanks Vette Noob, I checked the engine codes....
Here is what I have:
P0171
p0174
It says Fuel Trim system lean for bank 1 and 2.
I forgot to note in my origninal post that for the lastr few weeks when I get on the gas I get the lean ping sound from under the hood. I new that it meant lean but thought it was a fuel issue even though I use super premium.
Can you help by telling me what is the cause of these codes and what $$ / parts I may need???
Thanks again,
mcmtac14
Old Apr 27, 2006 | 11:05 PM
mcmtac14's Avatar
mcmtac14
Default check engine lite on - need help
Does anyone have any ideas on what would cause the codes in my post above???
Sleepless in philly!
mcmtac14
Old Apr 28, 2006 | 12:21 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Old Apr 28, 2006 | 10:00 AM
mcmtac14's Avatar
mcmtac14
Many thanks all for comments!
Mr. Goodwrench fixed the problem ..... 3 injectors were dirty most likely due to bad gas from the change over that is going on to the new fuel mixtures....
Regards,
mcmtac14
Old Apr 28, 2006 | 10:33 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Regards,
mcmtac14
Old Apr 28, 2006 | 12:21 PM
c5chris's Avatar
c5chris
Isnt this place awesome???!! You learn something new everyday
To Check engine lite on...need help
