[Z06] Bleeding the Brake System
Old Apr 28, 2006 | 08:36 PM
jaccfrost's Avatar
jaccfrost
Default Bleeding the Brake System
Anything special to do when doing this? Thanx
Old Apr 28, 2006 | 09:18 PM
Shylor's Avatar
Shylor
There is a certain order to it. The farthest location first.
Old Apr 28, 2006 | 10:16 PM
eschantra's Avatar
eschantra
IMHO, spend $30 or so and get a cheap vacuum pump. No second person required and saves some time. Also allows you to change your clutch fluid in about 30 seconds!
IVOZO6's Avatar
IVOZO6
Order to bleed: RR, LR, RF, LF
A dealer would use a Tech II to activate the abs.
What I do after I bleed is take it out and activate the abs a couple of times.
Come back and rebleed the system.
Old May 1, 2006 | 04:08 PM
Rob 2K1's Avatar
Rob 2K1
I believe the order changed in 2001. My '03 service manual list the order as: RR, LF, LR, RF.
Old May 2, 2006 | 09:18 AM
FasterIsBetter's Avatar
FasterIsBetter
I just did mine, and that was the order in the manual. '03 Z. A friend of mine came over and it took us all of about 10 minutes, but I already had the car up on the lift in the garage with all 4 wheels off, as I had just done a full brake job (pad, rotors, brake hoses).
Old May 2, 2006 | 12:26 PM
theDarkness's Avatar
theDarkness
Earls Solo-bleeds make the job very painless and you only need a single person to do it. I have a 2002 Z and used the farthest location first technique and my brakes work just fine.
--C
Old May 2, 2006 | 12:34 PM
IVOZO6's Avatar
IVOZO6
My mind is still "Back in the day"
Old May 2, 2006 | 12:42 PM
vms4evr's Avatar
vms4evr
Have you actually seen air bubbles after doing the ABS exercise and rebleed? I got the impression the Tech II cycles the heck out of the ABS enough to get trapped air but doing it on the street engaging ABS just doesn't cycle the relays/valves enough.
Old May 2, 2006 | 12:58 PM
IVOZO6's Avatar
IVOZO6
No air bubbles, I only did that cause a was swapping the brake fluid to ATE Super Blue.
Just to get as much fresh fluid in as conceivably possible.
When doing a brake job, I do not believe any air can get into the ABS system.
Someone please correct me if I am wrong.
To Bleeding the Brake System
