C6 Shifter For C5
Old Apr 29, 2006 | 04:16 PM
bigsteff's Avatar
bigsteff
Default C6 Shifter For C5
Where can I find the C6 style shift **** and boot for my 04 C5? Is it just the **** or do I have to change the shifter as well?
Please advise
Old Apr 29, 2006 | 04:36 PM
shakainc's Avatar
shakainc
If you want just the ****, Ecklers has styles similar to a C6. Part# 40178. I'm sure other vendors carry them to.
Old Apr 29, 2006 | 05:48 PM
Ohiostatefan's Avatar
Ohiostatefan
you will need everything.....the **** on the factory c5 is held on by a demon key.
the c6 is a screw in to side of the shifter.....so you'll need to buy both.
you can get the boot from your current c5 to fit though....a little modification work needed to get the boot over the bolt that holds the **** on.
try fred beans (vendor hear) or the used parts section...i got my shifter there and then ordered the **** from fred bean.
hope that helps.
Old Apr 29, 2006 | 06:20 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Ebay has them that are modded to fit a C5 style shifter.
If you want the shifter as well, (shorter throws) you can get the whole assembley from Fred Beens or Fitchners
Peace
Willfulone
__________________
..................Click for
Old May 1, 2006 | 11:38 AM
bigsteff's Avatar
bigsteff
If I order the entire assembly and shift ****, what color will it be? Do I have options?
To C6 Shifter For C5
