Hud Showing wrong info
Old Apr 30, 2006 | 12:06 AM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
Default Hud Showing wrong info
Searched the Forum for HUD but could not find anything on this issue.
Pulled the battery to try to reset an issue with the AC vents not working properly. Left the battery out for about 30 mins. Put together and went for a drive. The regular guages read fine. I filled the fuel up and read full in the analog guage, but the HUD read aprox 3/4. There is also the oil can in the hud, but I have normal pressure in the analog and the digital in the DIC. Hud was reading fine before hand. I have no DIC error codes appearing and no check engine warnings or light.
Old Apr 30, 2006 | 12:14 AM
TNT Vette's Avatar
TNT Vette
Try pressing and holding the "page" button located not with all the other DIC options, but on the driver's left with the HUD dimmer. You will also find that you can select all sorts of cool options with this button (just MPH, just RPM, etc.).
Old Apr 30, 2006 | 12:29 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Old Apr 30, 2006 | 12:33 AM
VLVETTE's Avatar
VLVETTE
Your HUD is fine it's just showing the oil info.
Old Apr 30, 2006 | 01:38 AM
GrayC5's Avatar
GrayC5
Sounds as if your HUD may have changed pages when you disconnected the battery. Your owner's manual cover's setting of the HUD so you can set it as you like. Good luck.
Old Apr 30, 2006 | 08:07 AM
But don't know why the HUD would show 3/4 tank of gas when the car is full.
Old Apr 30, 2006 | 08:11 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Becuase the HUD was showing oil pressure (the oil can) not the fuel level.
Old Apr 30, 2006 | 10:08 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
When you disconnect your battery or your battery is weak, the HUD goes into a default mode when the car starts up. As TNT (above) suggests, reset the HUD w/ the page button. You should be fine if your battery is good.
Old Apr 30, 2006 | 10:12 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The oilcan symbol simply means the right bargraph is displaying the oil pressure.
Press the page button until you see the fuel pump icon, then the bargraph will be displaying the fuel level.
Old Apr 30, 2006 | 11:12 AM
HummelS's Avatar
HummelS
The owner's manual is your friend....
Old Apr 30, 2006 | 11:31 AM
jsdanehy's Avatar
jsdanehy
Senior Member
Cruise-In V Veteran
To Hud Showing wrong info
