Getting first corvette
Old Apr 30, 2006 | 04:40 PM
GK VETTLOVER's Avatar
GK VETTLOVER
Default Getting first corvette
I will be getting my first Corvette this month I cant wait .Its been 46 (my age) years in coming It will be a C5 ( I love that body style) my question is what is the difference between 98 and 2000? they look the same the two that i am looking at have the about same options. I live in Texas so I am checking out the Corvette Palace ( herad that that is a good place) Also wich is better a 6-speed or auto? would like you guys opinion on this thanks
Old Apr 30, 2006 | 05:54 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Welcome - you're first good find was discovering this place! There are no shortage of answers here - some of them are even occasionally right!
Visually - there really aren't significant differences in outward appearance between the '98 and '00. There are some small differences, but to the general public - they all look the same. Here's a link that will discuss in detail the differences and the availability of some options between the model years. http://corvetteactioncenter.com/specs/index.html
Some colors were available for certain model years only - other than the standards like Torch Red and Black. Even the whites were different in different years. Several different shades of silvers were available through the C5 run - and then there were special colors available only one year, lioke Anniversary Red, LeMans Blue etc.
Over the model run - certain options eventually became standard equipment. The best advice I can offer you is to buy the lowest mileage car you can afford regardless of model year.
There were three different body styles available on the C5 - the '97 was introduction of this generation, the following year in '98 was the first year for the convertible. In '99 the FRC (fixed roof coupe) became available, which became the Z06 in '01.
I won't get into the discussion/arguement about which is better - and MN6 (six speed) or an A4 (auto). That is a very personal decision that only you can answer.
Do your homework, figure out what you really want - color, option and mileage and then go for it! You'll never look back and enjoy every mile from that point forward! Good luck in your hunt!
Old Apr 30, 2006 | 06:05 PM
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
Welcome!
I waited 64 years for my Vette and ended up with a Torch Red FRC that had 8000 miles on it. It is spotless. From what I can telll the advice just given ---"The best advice I can offer you is to buy the lowest mileage car you can afford regardless of model year." is the way to go..
As for the MN6 vs A4--it's up to you. I have the MN6 and love it. However, if you are going to use the Vette in allot of heavy traffic, the A4 might be worth considering. Drive both and then make up your mind..
Good Luck!
Old Apr 30, 2006 | 06:10 PM
Frozenfire's Avatar
Frozenfire
Congratulations and welcome!
Whichever model you choose, might I suggest getting a CarFax report on it first to see whether it's been in an accident, etc.. Then (and this is not a plug necessarily) I would suggest purchasing the build sheet and window sticker through the National Corvette Museum so you can learn what options the car was manufactured with.
Lastly, once you're on the road, be sure to wave at your fellow 'Vette drivers (you'll see that topic here quite a bit).
Enjoy!
Old Apr 30, 2006 | 06:55 PM
VetteLag00's Avatar
VetteLag00
Be careful you are going to start a war here between A4 and MN6.
If you get the MN6 the car is likely to have the 3.42 gear set up. If you get the A4 you will be lucky to get 3.15's. It seems quite a few of the A4's are 3.15 just going by what I have observed here but 2.73 is the standard. Personally I don't know about the 2.73's but from what I have seen here people complain about them. I could have cared of less when I bought mine but now I am thankful I for the 3.15. If its an an A4 crawl under the car, assuming your under 250 pounds, and look at the pumpkin there should be a sticker on there that says what it is. If you get a 98 you are probably going to get one with wagon wheels. Next time you do an internet search or somehow get two photos of a 99 or older and an 00 or newer and look at the difference. Don't refer to the photo of BlackSedan's 98 those are not the stock rims and probably cost a lot of $$, if you find a 98 with rims like that its a big plus.
Good luck with your search, I hope you are as happy with your car as the rest of us
Old Apr 30, 2006 | 07:10 PM
kwest2u's Avatar
kwest2u
Default Cool - sounds good
age is only a number. Finally getting it is the key!
Old Apr 30, 2006 | 07:19 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
They are all awesome, all years, colors, trannies, rear ends, etc... All, period.
btw, get a 2003 black z06 (6spd only)..... j/k
(see sig)
Old Apr 30, 2006 | 07:32 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Welcome to the forum. Choices like color and manual or automatic are really personal preferences and you will likely get a mix of opinions on the topic. Randy (blacksedan87) about has you covered with the facts The differences between the '98 and the '00 are subtle to say the least. Stock to stock you'll hardly be able to tell. Here is a link to a list of model year differences.
http://www.jakelatham.com/C5/misc/differences.shtml
Here is a nice site to give you the ins and outs of the tech specs for each of the model years:
http://www.corvetteactioncenter.com/specs/index.html
Enjoy the reading and enjoy the search for your perfect car. These cars are special in their own right and the folks here on this forum are some of the finest around. You won't find a more knowledgeable bunch on all things Corvette.
Paul
Old Apr 30, 2006 | 07:40 PM
LivinMyDream's Avatar
LivinMyDream
Hey, I waited till I was 47 before I got my first vette. A 2003 ML with an A4 and only 3,000 miles on it and I love it. Of course it has a little over 8,000 miles on it now after I have had it for almost a year and it still smells new inside.
I always wanted a corvette, but when I was in my teens, I could afford the car but not the insurance. In my mid twenties, I was raisng 2 children with my wife and paying for a house and couldn't afford anything. Now that I'm in my late forties, I finally got the car I always knew I one day would own, hence my user name.
Good luck and enjoy.
Old Apr 30, 2006 | 07:55 PM
jrose7004's Avatar
jrose7004
They're all good! Congrats!
shannanl's Avatar
shannanl
Congrats on the Vette. I am sure you will love it no matter which you get.
Old Apr 30, 2006 | 08:13 PM
intmd8r's Avatar
intmd8r
Old Apr 30, 2006 | 08:34 PM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
You have waited a long time, get what you want, and enjoy!
Old Apr 30, 2006 | 09:44 PM
GK VETTLOVER
Wow You guys are the best Thanks I got alot of info. I know I will be very happy once I get my C5. Such seeing one gets me
Old Apr 30, 2006 | 09:51 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
St. Jude Donor '06
Other then interior temp controls, wheels and hp difference in the ZO6 after 2001 b/c of dual cats, no biggie.
p.s Don't listen to anyone from the Phoenix area.
Old May 1, 2006 | 12:25 AM
GrayC5's Avatar
GrayC5
For differences, you might like to check out the following links:
C5 Model Year Differences
Corvette Model Center
Good luck finding the right C5.
Old May 1, 2006 | 01:13 AM
edensknight's Avatar
edensknight
Congratulations to you! Glad to have you aboard! Enjoy!
To Getting first corvette
Old May 1, 2006 | 01:28 AM
c5coast's Avatar
c5coast
Congrats on your Corvette...a long time coming fo a lot.
Old May 1, 2006 | 06:51 AM
On the '00, you might be able to get options like the HUD and active handling. Nice things to have. The '00 also does not have a passenger side key hole for the door and if you get a mid year '00, you may also have the passenger side airbag cutoff switch. Good luck in your purchase of a C5.
Old May 1, 2006 | 07:50 AM
Dark-Knight's Avatar
Dark-Knight
Get the newest with the lowest milage. M6 or A4 is a matter of driving environment needs and personal taste.
Cya 'round town!
