Wheel Bearings
Old May 3, 2006 | 04:19 PM
fsa00120's Avatar
fsa00120
Default Wheel Bearings
I just had the right side front wheel bearing replaced. The left one was replaced last fall. I started noticing that when making a left hand turn (not speed related) I would hear a roaring noise. When I turned right - no noise. Since I have extended warrenty off to the Chevy dealer that I trust and they confirmed the right bearing was toast.
What bugs me is the Vette only has 37,750 miles on the ticker - makes you wonder if the sealed bearing are designed correctly.
Old May 3, 2006 | 06:58 PM
Cole's Avatar
Cole
Things fail. Very few reports of this problem on the forum.
Old May 3, 2006 | 07:15 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
yes, that noise is typical of a failing bearing. Makes me wonder if the bearings you got were packed with grease. In our shop, we have seen TONS of malibu, monte carlo, and lumina OEM tie rods fail prematurely, in which I believe these rods did not come with grease from the factory(and are not greaseable). Makes me wonder about the if this was intentional??? What a great money maker GM would have over the course of 5 years......
Old May 11, 2006 | 03:58 PM
b.j.prescott's Avatar
b.j.prescott
just wondering if you bought the car new??I have the same problem & the lady I bought it from had hit a curb, as evidenced by the marked whl.,also on the right side.The left is also good....
Old May 11, 2006 | 04:28 PM
LoneStarFRC's Avatar
LoneStarFRC
121,000 miles on my original ones.
Old May 11, 2006 | 04:53 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I changed all 4 at 45,000 miles. The 2 rear ones were shot - you could hear them on the dyno - so changed all 4.
AutoZone replacements are actually much better quality than original OEM - go figure. Oh, and less than 1/2 the price
Old May 11, 2006 | 05:47 PM
Sometimes thing just fail prematurely. At least you are covered by an extended warranty. Doesn't make up for the aggravation, but the money impact is lessened.
Old May 11, 2006 | 08:51 PM
jman1's Avatar
jman1
i just replaced one at 70k
Old May 11, 2006 | 08:58 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I got a rear one doing some whining now. Been putting it off as long as I can, but this is one more reminder....
Old May 11, 2006 | 10:44 PM
edensknight's Avatar
edensknight
My first rear bearing hub assembly unit had to be replaced at 11K. Timken bearings for the C5 are available at the Autozone.
To Wheel Bearings
