Ticking Sound?
Old May 3, 2006 | 09:46 PM
Rob Harkins's Avatar
Rob Harkins
Default Ticking Sound?
I just had some work done to my 2000 C-5 Convertible. Installed long tube headers,high flow cats,adaptors,merge style pipe,02 wiring extenders etc. A new black wing air intake,Billy Bob exhaust,fuel filter,plus,wires and a LS1 Editor Custom Program. Now even after the car is warm there is a ticking sound coming from what seems like the headers.It almost sounds like the Fuel Injectors echoing inside the headers is this possible? Any info would be appreciated. Its also an automatic.Otherwise than that it sounds amazing and certainly has picked up some horse 60 on the dyno to be exact.
Old May 3, 2006 | 09:50 PM
Mpwr's Avatar
Mpwr
Once I installed mine I realized the same thing. I also read a thread b4 this explaining the same noise, so I guess this is common. Ive had them on the car since fed and no probs other than the ticking and more power! Hopefully this helps
Old May 3, 2006 | 09:52 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Usually normal. Keep in mind that headers are higher quality (but thinner) metal, which "muffles" less of the normal sound.
If it is really bad it could be an exhaust leak, but probably nothing to worry about...
Mine tick too (normal ticking)...
Old May 3, 2006 | 10:11 PM
LoneStarFRC's Avatar
LoneStarFRC
I agree with the others. Probably fuel injectors and/or the occasional sound from the evap purge solenoid (although it doesn't operate continuously). The smaller more slender size of the Bosch injectors may also be a contributing factor to their being heard more easily.
Old May 3, 2006 | 10:38 PM
Rob Harkins
O.K.so I should just learn to live with it and enjoy the extra ponies!!
Old May 4, 2006 | 05:51 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
I had a louder ticking noise occur in my car after i put my long tubes in. I believe it's from the rockers and since your exhaust is open so much more because of the LT's you can hear them a little louder.
Old May 4, 2006 | 05:54 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Mine does it too. The guys at LG said it was normal. I'm glad too see I'm not the only one.
jeff
Old May 4, 2006 | 07:01 PM
Hammie's Avatar
Hammie
That's a billy boat exhauast, man. Just incase you explained it to anyone else.
Old May 4, 2006 | 09:31 PM
Rob Harkins
Billy Boat my bad!!!
Old May 5, 2006 | 05:59 PM
edensknight's Avatar
edensknight
But, don't worry. No damage done.
To Ticking Sound?
