If you are asking about C6 Z06 calipers I do not know the cost.
If you are talking about C5 Z06 calipers read below.
If you really need them, I believe they run about $349, BUT if you are only getting them because you want red calipers, I would strongly suggest you just paint your existing caipers.
The C5 Z06 calipers mechanically are the same as you have on all other C5's. The color is the only difference.
I painted mine 4 years ago at a total cost of under $3 and they look great in my opinion. Rustoleum Sunrise Red Gloss paint.
You can expect to pay $399.00 for the red ones and the red is the only difference from what you have on your car.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
And....not only will you save the $400 to buy the calipers - you don't have to take the existing calipers off to paint them. So you save the labor cost to install new calipers, bleed the brakes, etc.
I did two coats of spray, and then touched up with a small brush. I would go with a bursh kit. No clear needed. The calipers do not get real hot, but I went with a high temp pain just in case since I'm starting to do HPDEs now.
I would suggest thinking of painting the carrrier as well, I did mine the traditional red and then made the carrier aluminum color and it looks really good IMO.
If you can pull the calipers, then really look at getting a set of drilled/slotted rotors and really dress it up!: thumbs:
I agree - just clean up your current calipers and paint them with some caliper paint. They will look just as good and you'll have a lot more money for other mods.
I put on 3 coats of Duplicolor red caliper paint on mine and they came out great! A CF member had recommended putting a coat of chapstick on the letters to help the paint come off easier afterwards. Seemed to work great for me...
