Transmissions available in C5's
Old May 5, 2006 | 03:39 PM
76custompaint's Avatar
76custompaint
Default Transmissions available in C5's
Hi, I've never posted in this forum before, I usually hang around in C3.
I've made a nice little tool to show the top speed in different gears and where you end up in your RPM range after shifting, but right now all I have are the transmissions for C3's and some newer auto trannies.
I would like to extend this tool for the other generations also, and I was wondering what transmissions came in what years of C5's and what their gear ratios are so I can add them to my site?
P.S. the site is at http://76custompaint.homeip.net
Old May 5, 2006 | 04:35 PM
76custompaint
I'm sorry it looks like this is all in the EXCELLENT FAQ you have up, now that's something C3 could use :o
Sorry again, enjoy the site
Old May 5, 2006 | 04:45 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
A4 (automatic) ratios are as follows
1st 3.06
2nd 1.63
3rd 1.00
4th 0.70
The manual boxes are the MN6 and the MN12. The 12 is for the C5 Z06 only. I don't know the ratios for them
You might want to look at this site too - http://www.f-body.org/gears/
EG
Old May 5, 2006 | 04:50 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Everything you want to know is here>>>
http://www.idavette.net
Or you can go here http://www.corvettemuseum.com/specs/2001/specs.htm & scroll down to gear ratios.
Old May 5, 2006 | 05:33 PM
ChevyChad's Avatar
ChevyChad
M6
1) 2.66
2) 1.78
3) 1.30
4) 1.00
5) 0.74
6) 0.50
M12
1) 2.97
2) 2.07
3) 1.43
4) 1.00
5) 0.84
6) 0.56
To Transmissions available in C5's
