Fuel Questions?
Old May 5, 2006 | 08:07 PM
rkhegler's Avatar
rkhegler
Default Fuel Questions?
For those of you who have a C5, what octane fuel do you burn? Do you or have you ever added an octane additive? What brand do you use? Do any of you use Ethanol blends?
Old May 5, 2006 | 08:30 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mobil 93
Old May 5, 2006 | 08:54 PM
dwilcox's Avatar
dwilcox
If I could find some 93 in Arizona I would use it but I buy Chevron 91 Octane. A word of caution, or so I was told by my GM dealer, I used to use 104 Octane Booster on a fairy regular basis, say evry other tank. It recently started to idle rough which turned into a light miss. We found it needed a set of plugs, My 01 only has 26,000 miles on it. Dealer said that prolonged use, or leaving it in the tank too long before it is used up will eat a set of plugs. I know, I know, stealerships, but my guys do take care of me and the rough idel and miss are gone, and yes they gave me the plugs. Do what ever trips your trigger, but I would just buy good gas, keep the intake system clean, and avoid any in the can additives. At least that is my .02 cents. Have a good one!!
Old May 5, 2006 | 09:01 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I guess it's time for the weekly question on octane again. I use whatever grade comes out of the premium pump, same as last week's answer.
Old May 5, 2006 | 09:06 PM
rkhegler's Avatar
rkhegler
Sorry I bothered you. As for the other posts, thanks for the info.
Old May 5, 2006 | 10:46 PM
ksmagellan's Avatar
ksmagellan
I buy Premium 91 Octane and always try to get it from a dealer that markets "Top Tier" gasoline. BP, Shell, and Quik Trip in our part of the world. A couple times a year, I'll run a bottle of Techron thru the fuel system just before changing the oil...cleans up any deposits that may have built up. So far...so good!
Old May 5, 2006 | 10:52 PM
TheWolverine's Avatar
TheWolverine
93 octane Amoco fuel from BP.
Old May 5, 2006 | 10:54 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Major brands, premium grade.
Old May 5, 2006 | 10:55 PM
ja03c5's Avatar
ja03c5
Just follow the instructions..."PREMIUM UNLEADED"
Old May 5, 2006 | 11:44 PM
Tom73's Avatar
Tom73
Won't work in a Vette. Since you burn more Ethanol to get the same amount of energy as you would from gas you need different components that will deliver a higher flow rate. Those certified for Ethanol has larger fuel pumps, larger injectors, and sensors to tell the computer what % of ethanol you are using so that the computer can adjust the flow as needed.
tom...
Old May 5, 2006 | 11:54 PM
This is true if you burn something like that has a higher percentage of ethanol in it. Here in Missouri most of the stations have a 10% ethanol blend available - I've run it in mine and it does just fine. No decrease in gas mileage and the car's performance has remained good.
Old May 6, 2006 | 12:02 AM
MY1STPEWTER's Avatar
MY1STPEWTER
Shell V Power 93, and every blue moon BP premium.
Old May 6, 2006 | 03:31 PM
Tom73's Avatar
Tom73
Was thinking in terms of the E85 and E95.
tom...
Old May 6, 2006 | 05:21 PM
BiggieBoy's Avatar
BiggieBoy
Shell or Marathon 93 octane. All the gasoline in the Chicagoland area are blended w/ 10% ethanol and have been for years...
Old May 6, 2006 | 05:48 PM
rws.1's Avatar
rws.1
Shell V-Power 93 Octane...
Why?
I don't want clogged injectors or a fouled fuel sending unit screwing up my gas gauge...
www.toptiergas.com
Old May 6, 2006 | 07:28 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I only use sunoco 93 the only additive i use is when i store the car for the winter and that is sta-bil..............
Old May 6, 2006 | 08:03 PM
Autoworker's Avatar
Autoworker
Preimum fuel ............Hypertech programming.
Old May 6, 2006 | 08:04 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I always use 93 octane and when in boost some methonal to boot
To Fuel Questions?
