I just had Bilstiens installed a few weeks ago and ever since, if i go over a series of bumps, I hear this "rattle" that seems to be comming from the front suspension. I didnt have this before the install. Anyone know if this is the shocks and normal or do I have something loose?
Thanks!
Mine rattled when I first put them on. I had used the mounting hardware from the stock shocks because I thought it looked like it fit better. They worked loose in a day so I replaced the hardware. No more noise so check tightness.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Use the Bilstein mounting hardware and it should be silent. If you have a noise, that is not a good thing. As others have said, make sure everything is tight.
