just got in my 97 today and check engine light came on with the traction control light and the dic said service traction control system. anyone ever have this problem? what is the fix? anyone know?
looked it up on the code list and i did not see it on there..i got the service tcs,AH,and abs..it went away and everything works...im goin to clean all the grounds like that one guy said to...
I had a similar problem a while back. It happeend sporadically but typically afte a few minutes of driving. I didnt remember my exact code but it referred to the front wheel hub. There is a TCS wiring harness coming out of each wheel hub. someone told me to clean them with that dilithium stuff. Probelm went away after that.
My 98 coupe did that everytime I went over railroad tracks to fast. My 99 just did it to me the other day when I was on a very very bumpy road. I forget what the codes where but I know the ground cleaning thing is a cure for it.
Good luck
Jim
