[Z06] Body side molding removal
Old May 7, 2006 | 07:46 AM
Bwest06Z06's Avatar
Bwest06Z06
Default Body side molding removal
Anyone have any tips for removing the bsm without damaging the paint ?
Old May 7, 2006 | 10:51 AM
Andy64's Avatar
Andy64
Heat them a bit and use fishing line. Thats how most have removed them.
Old May 8, 2006 | 01:21 AM
Stiffy's Avatar
Stiffy
When you heat them useing a blow dryer or heat gun make sure you dont burn the paint!
Old May 8, 2006 | 08:11 AM
ls1mtz's Avatar
ls1mtz
http://www.corvetteflorida.com/forum...hread.php?t=40
Old May 8, 2006 | 11:54 AM
deathtrap's Avatar
deathtrap
i took mine off last weekend. i just pulled them off and used a 3m gummy eracer like wheel to take the sticky stuff off
Old May 8, 2006 | 10:33 PM
ROMISZ's Avatar
ROMISZ
I have a EB Z06 with BSM's, I will probably taking them off this week.
I owned a Black 2000 FRC before the Z06, which I took the BSM's off myself.
What I used was 3M Adhesive remover, you can find it in almost any Auto parts supply store in the paint section. It comes in a small rounded rectanglur can with a plastic screw-type cap on top.
I placed a small amount in a small cap like container, and dosed the end of Q-tips in it and then soaked the BSM's from the top. The 3M liquid did not harm my paint. After letting it soak to loosen the adhesive, I started pulling with either my finger nails or a weed waker line until there was a leading edge. I then changed to a plastic Ty-Rap. The reason I changed to the plastic Ty-Rap, is that it was a flat surface to pull with, rather then a round surface which I saw started to leave marks in the edges of the BSM. You will see what I mean when you try it. I wanted to keep the BSM's in good shape, I still have my Black ones. No paint discoloration was seen at all. You can use the 3M stuff to rub off the excess glue, or your fingers and hand in a rubbing motion.
Just take your time, it is scary the first time, but by the time you get to the last piece, you will be a pro, and wonder why Chevrolet put them on the car, its a Sports car not a grocery getter!
..................Robert
Old May 8, 2006 | 10:58 PM
slong's Avatar
slong
Originally Posted by ROMISZ
Its a Sports car not a grocery getter!
Mans gotta eat too!
To Body side molding removal
