ac help
Old May 7, 2006 | 05:28 PM
spdlvr's Avatar
spdlvr
Cruising
Default ac help
today I went to use the ac and can not control the temperature ,when I turn the **** either way
the temp. goes 70 to 72 , then I could not shut it off ,it went off after a few tries but when I turn it back on it does the same thing ,any ideas ?the actuator was changed 6 month ago and everything was working fine until now
Old May 8, 2006 | 12:22 AM
spdlvr's Avatar
spdlvr
Cruising
ttt anybody ?
Old May 8, 2006 | 12:25 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
have you tried pulling the a/c control fuse? see if resetting it that way helps.
Old May 8, 2006 | 12:32 AM
spdlvr's Avatar
spdlvr
Cruising
already tried , did not work
Old May 8, 2006 | 06:11 PM
spdlvr's Avatar
spdlvr
Cruising
ttt anybody please
Old May 10, 2006 | 09:14 PM
spdlvr's Avatar
spdlvr
Cruising
ok I found a couple of guys on ebay that fix the ac control panel, but my particular problem is unrepairable , luckie me ,need a new one ,thanks GM for putting cheap parts in our cars ,I had cars with auto climate control for the last 15 years and never had one go bad ,some of the cars had well over 100k m. but this seems to be a very common problem with c5s,figure I let you guys know.
To ac help
