Bad Crash--need Help
Old May 7, 2006 | 05:41 PM
mk8k8's Avatar
mk8k8
Default Bad Crash--need Help
Hey guys,
I just bought my first C5 corvette, had it for about 5 months now. Unfortunately some IDIOT decided to use my car as his brake in traffic. The damage was very extensive. I was wondering if anyone knows or has experience taking off the back bumper to check for structural damage or frame damage. Does this involve taking of the wheels? Please HELP, I want to get a good gauge on my estimate?
Old May 7, 2006 | 05:48 PM
c5vette_dallas's Avatar
c5vette_dallas
sry to hear that guy..just got my front end fixed from some idiot backing onto my car..here is a bump for ya!
Old May 7, 2006 | 06:07 PM
ebubman's Avatar
ebubman
sorry to see it man. unfortunately driving defensively these days means watching every direction around you. bub
Old May 7, 2006 | 06:43 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
I haven't done it but you might PM Randy blacksedan87. I know he's done it. Good Luck!
Old May 7, 2006 | 07:19 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Did this person have a cellphone stuck in their ear?
Old May 7, 2006 | 08:24 PM
Lancer033's Avatar
Lancer033
yes, you do have to take the wheels off, but with the size of that hole, you can probably see everything w/o taking it off. Sorry about your car and good luck with the repairs
from http://forums.corvetteforum.com/show...23529#poststop
I wrote that from memory after doing it, but it's not that bad
Originally Posted by Lancer033
Steps for removing the rear fascia
1. lift the car, put it on jack stands, remove the rear wheels.
2. remove the wheel wells, there are 8 7mm bolts holding it in place, the last one is under the side rocker panel.
3. reach up to where the rear fascia meets the quarter panel, there are 4. bolts that you can reach from here, I think they are 11mm
5. under the car, there are 4 tabs. These things are a bear to get out, I'm sure there is a trick to get them out, but I ended up using a crow bar.
6. back outside the car, remove the licence plate bracket, 4 torx screws and the tail lights, 2 torx screws each. and disconnect the bulbs
7. reach in the outer tail lights and you can get to a few more screws, 11mm I think, same size as the ones in step 4
8. behind the licence plate bracket, there are 2 screws that I'm not sure how to describe. They have a large head about 1" in diameter painted the same as the body with a square tip. I just used the torx bit and forced it in. They were not on very tight
9. the last thing to do is lift the trunk and unscrew the torx screws along the top.
10. then carefully lift up and out. Before you get to far, hold the fascia with one arm and reach in and pull out all of the connections for the tail lights, they are all on 1 string of wires and just pull out.
Old May 7, 2006 | 09:40 PM
ja03c5's Avatar
ja03c5
Sorry about your car man!!!
Old May 7, 2006 | 10:13 PM
mk8k8's Avatar
mk8k8
Thanks you very much , this was very helpful. now i just have to beable to do this..
Old May 8, 2006 | 12:10 AM
TA8088's Avatar
TA8088
That sucks! Hope you get everything fixed.
Old May 8, 2006 | 12:12 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sorry to hear of your misfortune. You ought to fill out your location in your profile. Maybe some CF members can post a good vette body shop in your area.
Good luck on the repair.
Old May 8, 2006 | 12:13 AM
C5LawnGnom's Avatar
C5LawnGnom
Sorry to hear, That really sucks bro... I'm feeling for you. But I think you got lucky... I would consider that minor damage for someone rear ending you hard. I saw another vette get rear ended and you could see the dash from the liscense plate. If your axle and differential and everything is ok than this shouldn't be a humongous cost. Although it is gonna stink not driving for a while.
Old May 8, 2006 | 02:06 AM
Lancer033's Avatar
Lancer033
I hate to ask the dumb question, but why are you trying to do any thing to it yourself? Wouldn't it be better to just let a body shop do the work and let the insurance company take care of the bill?
Old May 8, 2006 | 02:41 AM
ZubikC5's Avatar
ZubikC5
Where are you located? In Lewisville Texas there is a great shop called Dusolds Designs. Mike Dusold is the owner. They do awesome work.
Old May 8, 2006 | 06:30 AM
Dark-Knight's Avatar
Dark-Knight
Oh man! I woulda killed 'em!
Old May 8, 2006 | 10:25 AM
filmelf's Avatar
filmelf
St. Jude Donor '06-'08
It would be best to go through your insurance company. Not only will your car be repaired properly but the A$$ who rear-ended you will have no choice but to pay and won't be bothering you. They do try to make you assume the responsibility for it all.
Good Luck!!!!
Forrest
Old May 8, 2006 | 10:33 AM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Especially if the insurance company has to pay to have it fixed anyway.
If he does something to the car himself, could the Insurance Company come back and say that he caused more damage and lower the amount of money they pay out?
Old May 8, 2006 | 10:34 AM
ATLRIDER's Avatar
ATLRIDER
7th Gear
What an idiot!
To Bad Crash--need Help
Old May 8, 2006 | 01:15 PM
Craig Wagner's Avatar
Craig Wagner
I do not know for certain, but I do know that insurance companies will look for any excuse to reduce their payout, so I would guess this is a pretty reasonable assumption.
Old May 8, 2006 | 01:19 PM
cooluhl's Avatar
cooluhl
Especially if the dude that hit him is at fault, then that person's insurance should be involved. Unless he didn't have insurance. But either way, this is shy we pay those high premiums. I wouldn't touch my car with a 10-foot pole in this case. Let the "pros" handle it.
Old May 8, 2006 | 01:44 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
Oh man - that'a a jaw dropper.
Sorry to hear about this - hopefully you can get your car fixed and on the road again soon.
