Hey SFengineer!
Old May 7, 2006 | 07:54 PM
PrayN4C5's Avatar
PrayN4C5
Default Hey SFengineer!
Hey i had sent you a message awhile ago regarding the retrofit you did on your c5 and i still have some questions as to how you went about it. I finally got some bosch bi-xenon projectors off the internet and am searching for the bulb/ballast for now. How exactly did you go about centering and mounting the projector into the headlight assembly? I have found that a 3.25" hole saw will cut a perfect hole for my projector but im not sure how far in i should situate the front of the projector. If you have any pictures this would really help me out. I only have one set of housings so i cant screw this up
And also, your box is full!
Old May 8, 2006 | 09:34 AM
PrayN4C5's Avatar
PrayN4C5
where are you?
Old May 8, 2006 | 11:28 PM
PrayN4C5's Avatar
PrayN4C5
im in dire need of some help here
Old May 9, 2006 | 12:40 AM
lewishou's Avatar
lewishou
You may want to post this in the Norcal section. I know he posts over there. Good luck.
Lewis
To Hey SFengineer!
