[Z06] Need help aligning tips
Old May 9, 2006 | 07:52 PM
ricoZg's Avatar
ricoZg
Default Need help aligning tips
Hello! When I purchased my Z over a month ago, I noticed that the stock tips weren't aligned properly. I'm not sure if the right side's too low or the left side's too high.
Here's the only pic I have of the rear right now:
How do I go about aligning this?
Thanks in advance!
Mike G.
Old May 10, 2006 | 12:47 AM
striper's Avatar
striper
Your right side tips are too low. I would check to see if there is a problem with the rubber mount where the tab on the muffler fits in to. If that is the stock exhaust it's the only place I can think of that would cause your muffler to hang down.
Old May 10, 2006 | 12:52 PM
ricoZg's Avatar
ricoZg
I'm pretty sure it's the stock Ti exhaust, it was on the car when I bought it in March.
I'll check out the rubber mount when I get home tonight.
Thanks!
Mike G.
Old May 10, 2006 | 12:53 PM
DPG's Avatar
DPG
St. Jude Donor '06
also, you can make adjustments where the cat back attaches to the h-pipe. There are 2 bolts that attach to the muffler section infront of the rear axle. Loosen those bolts and have someone hold the tips in the right position while you tighten up those 2 bolts. Very simple job, but can take more than one try to get it right
Old May 10, 2006 | 01:14 PM
ricoZg's Avatar
ricoZg
Well, I guess it's time I get some jacking pucks so I can take a look under the car.
Mike G.
Old May 12, 2006 | 05:32 PM
99vettecoupe's Avatar
99vettecoupe
Loosen the bolts at the H-pipe. Take a jack and a piece of wood wide enough to touch both sides of the exhaust tips. Put the wood on top of the jack and slowly jack up the tips until they line up where you want them. Leave the jack in place then tighten up the bolts. When you lower the jack the tips will stay where they were. It's a real easy way to do it yourself.
Old May 14, 2006 | 12:19 PM
Bobs dream's Avatar
Bobs dream
Except I used some spring loaded clamps to hold the wood to the tips
To Need help aligning tips
