Need Help Please
Old May 11, 2006 | 09:21 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Default Need Help Please
I need to replace the interior driver's side A-pillar trim panel on my '99 C5. I need to hear from anyone who has removed and/or replaced this piece and has instructions/advice on how to do it. I have a new trim panel coming. Any thoughts/advice would be greatly appreciated.
Old May 11, 2006 | 10:08 AM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
Try browsing some of the web sites of companies that may sell the pillar. They possibily may have "how to" instructions. You could also try some of the supporting vendors that sell interior products...they may help even if you aren't a customer. Good luck.
Old May 11, 2006 | 10:59 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
It's REAL easy - so easy in fact that I can do it! It just snaps on and off. Just get a good grip on it and pull it off. Notice I didn't say yank it off - grab it and firmly pull it off.
Old May 11, 2006 | 11:01 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old May 11, 2006 | 12:57 PM
MattB's Avatar
MattB
Just pull it straight towards you. There are three tabs with metal retainers that hold it together by friction alone. If you can't get a good grip, use a pry bar of some kind to get it started (just be sure not to scratch anything. Check out the HUD install instructions, I started my HUD install last night and had to remove these to get the dash out.
Old May 12, 2006 | 05:38 AM
foremaw's Avatar
foremaw
You guys are great! Thanks for replies, I'll be replacing it today (and feeling much better about it.)
BTW, just so you know what happened: The knucklehead doing the car inspection got in it to scrape off an old decal and ran his razor blade across it cutting it open.
Old May 12, 2006 | 09:03 AM
jrose7004's Avatar
jrose7004
Couldn't be easier!
To Need Help Please
