Console Alignment ?
Old May 11, 2006 | 08:30 PM
CorvetteGirl-NM's Avatar
CorvetteGirl-NM
Default Console Alignment ?
This has been driving me nuts.......Is this normal - the way the console lines up with the rest of the dash? if not, how do I fix?
Old May 11, 2006 | 08:56 PM
CUlookin's Avatar
CUlookin
Mine has done the same thing and I've never been able to completely fix it. I have however adjusted it some by taking off that little cover next to the ignition (I believe it's a temp. sensor) and taking out that screw. With the screw out, push the console over and tighten it back down. That helped with about 1/2 the gap, but no more than that. Hopefully someone else will chime in with a better fix!
Old May 11, 2006 | 09:16 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That is normal, poor panel fit is a common problem. Nice for a flagship car
I am sure someone will chime in with a fix.
Good luck
rrram67's Avatar
rrram67
Seems like a bigger gap than usual... May be worth pulling it apart and trying to re-fit it.
Old May 11, 2006 | 09:18 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Mine looked like that the day I bought it new. Go to the vettessentials website for instructions on how to take the console out. Just loosen it and you'll see there are 2 serrated tabs on the top of it. They are supposed to hold onto the dash pad, but don't. I cut a couple of 1" squares out of some rubber mat. Tuck the squares between the radio and the tabs to keep them tight. My console has been good for 2 years and 24,000 miles now.
Old May 11, 2006 | 09:20 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
You can remove the center surround there are bolts that fasten the dash pad Loosen them push pad in place and then tighten them.
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Mine is almost the same and I have tried several times to line it up with no luck, so I deal with it, by ignoring it.
Old May 11, 2006 | 09:22 PM
CorvetteGirl-NM
Thanks for the tips all!!
Old May 11, 2006 | 09:24 PM
FiberglassFan's Avatar
FiberglassFan
Aw, bummer.....Mine does not look at all like that, everthing fits on my 98. However, I have to pull the console soon to change out the HVAC control head [ dreaded display death]. I will take a look at how those tabs fit and consider rubber shims as a way to MAKE SURE that the console always stays where it should.
Good luck on re-aligning it, and also kudos on the tips on how-to from the responding posters.
Old May 11, 2006 | 09:32 PM
BiggieBoy's Avatar
BiggieBoy
My '98 doesn't look like that either. The fit is where it's suppose to be.
Old May 12, 2006 | 12:08 AM
BrianWe's Avatar
BrianWe
The gap should not be that big. Unbolt your armrest (waterfall too if a vert) and slide the armrest back as far as it will go. Unbolt the 3 screws which hold the radio bezel on. Then start playing with it. There is a small tab near the horizontal part which is most likely causing the poor fit. Move it around until everything fits. The tabs which hold the top in are pretty tiny and won't work if you don't have it aligned properly.
I noticed a big gap the last time I had the console out, but only when I was in the passenger seat. I was able to eliminate it the next time I took it out and paid better attention to how it went back in. Before you put in all together, check out the view from both seats to make sure it is good.
Fixing this should be a half hour job.
To Console Alignment ?
