Help! Oil leak
Old May 13, 2006 | 10:56 AM
1Redctoo's Avatar
1Redctoo
Default Help! Oil leak
I hit a pothole on my way to lunch , ate and came out to find the '02 sitting in a puddle of oil ! No oil on the dipstick. I had it towed to a friends house so we can put it on his lift . If it is a hole in the pan , can this be fixed by a couple of back yard wrenchheads or should I take it to the dreaded dealer ? If it isnt the oil pan, where else should I look ? Also, does anyone have any pics of the underside of their C5 ?
Old May 13, 2006 | 09:40 PM
NetworkMD's Avatar
NetworkMD
The oil filter sits fairly low, please keep us posted good luck with the repairs.
Old May 13, 2006 | 10:08 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
You could have just punched a small hole in the filter, hope that is it. Remove it and see if it is dry too, and then look it over real good. It happened to me with another car I owned. It took me a few quarts of oil and a coupl eof days of driving it to find that a little lift and some investigating goes much further.
Old May 13, 2006 | 10:25 PM
Hope it is just the filter and not the oil pan. Have you found the source of the leak yet?
Old May 14, 2006 | 10:03 AM
1Redctoo's Avatar
1Redctoo
Default Leak fixed
Well the leak turned out to be a crack in the oil pan . I tried to find a new one but they wanted way too much $ . One place wanted 900.00 and I had to drive 3hrs to get it . Well, that didnt happen. I took it to a shop and had it welded , put it back on and no more leak ! Whew
To Help! Oil leak
