Need PCM removal Help!
Old May 14, 2006 | 06:12 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Default Need PCM removal Help!
I'm sending my PCM to Chuck at CoW. I found this thread on removing it but I'm a little confused as to what screws actually hold the PCM in the bracket. I got the outer bracket loose. Do I have to remove the 4 small screws holding the bracket?
here's the thread
http://forums.corvetteforum.com/show...&highlight=pcm
Old May 14, 2006 | 07:50 PM
printmanjackson
Ok, I figured it out. The missing instructions are that the "PCM slides out of the bracket toward the fender". The PCM's bracket doesn't need be losened. You do have to make sure the outer bracket back screw is lose enought but not removed.
Hope this might help anyone else with this.
