Guage Cluster: Remove Guage needles?
Old May 16, 2006 | 06:46 PM
spdnman's Avatar
spdnman
Default Guage Cluster: Remove Guage needles?
I am installing the EL Guages white faced guages. How do you remove the needles to slip the overlays on? Thanks.
Old May 16, 2006 | 06:51 PM
OUR97's Avatar
OUR97
Use a pointer puller. HUH? It is nothing more than a flat bladed screwdriver with a V ground into the flat then bent to 90 degrees to form an L shape. Any piece of sturdy metal will work. I still have mine from my tech school days many moons ago.
Old May 16, 2006 | 07:23 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Get a very small flat blade screwdriver, and gently pry the back of the base of the needle outwards - it will "pop" out.
Glue the new EL faces flat - do NOT use double sided tape, as it interferes with the sweep of the needles. I used contact cement, very thinly brushed on.
A word of caution; I discovered by experience that in order for the needles to read correctly after removal, they must be reinstalled with the cluster connected to the car - it must be receiving power. Otherwise you reading are going to be far off. My tach was at 2000rpm with the engine off - no matter what I did.
Other than that, it's a straightforward install - and no, the wires do not show at all.
Good luck
EG
Old May 16, 2006 | 07:50 PM
Mike Mercury's Avatar
Mike Mercury
here is a home-made needle removal tool I use when converting mechanical C3 tachs to electronic operation:
it's modeled after a GM tool I once used when I did these repairs
under warranty ...
but I'm not an old guy...
Old May 16, 2006 | 07:56 PM
spdnman's Avatar
spdnman
Thanks guys!
To Guage Cluster: Remove Guage needles?
