chrome hoops installed
Old May 18, 2006 | 09:03 AM
uknowme2good's Avatar
uknowme2good
Default chrome hoops installed
i just installed a set of chrome hoops in my 2000 vette. The problem i have is that i am not happy with how the carpet is finished around the hoops. I cut the rug nice but it dont look finished....
Anyone have any ideas to finsih this installation off like a pro??
pictures and vendor names would help with my search.
Old May 18, 2006 | 09:08 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
...I think I've seen a plastic ring of some sort that covers the carpeting around the hoops. Maybe someone here has a pic of their installation......Good luck....
Old May 18, 2006 | 09:17 AM
LoftyC5's Avatar
LoftyC5
Lets see some pics
Old May 18, 2006 | 09:32 AM
uknowme2good
yeah..i agree i know i saw someone with chrome rings installed around the base of the hoops ...
but i dont where they got them...? the rings would have to open in half to install then around the hoops...
pictures and a vendor phone number?
Old May 18, 2006 | 10:08 AM
Wildcat99's Avatar
Wildcat99
You can get the rings at Home Depot or Lowes. They are for plummbing use, I think to go around Shower faucets.They are either called a chrome trim ring od beauty ring, its been a couple of years and my memory isn't what it use to be.They are split and fit around the hoop at the carpet. You may have to trim it a little to make it fit better. I'll post a picture of mine when I get home. Hope this helps.
Old May 18, 2006 | 10:21 AM
Z0SLIK's Avatar
Z0SLIK
Old May 18, 2006 | 10:49 AM
Wildcat99's Avatar
Wildcat99
They are made from plastic, not metal. Easy to trim to fit.
Old May 18, 2006 | 11:16 AM
Tombone's Avatar
Tombone
If you want to replace the carpet and start from scratch I can tell you the technique for cutting the carpet for exact placement.
Once you have you bars are in place create a template with an exact diameter of the bar cut in it.
Place a cut in the template so it can fit around the bar.
Make the template about 10 inches long and fold in half.
You will need four separate templates.
Place each of the four templates around the bars and tape down the back extension of the template.
Fold back the templates and remove the bars.
Reinstall the carpet to be cut fold back the templates and trace your circles.
Remove the carpet and cut holes.
Replaced the bars and notch the carpet so it will go back in place.
Call me if you have questions 519.383.8075
Old May 18, 2006 | 12:03 PM
uknowme2good
i cut the carpet okay..if you looked at it you would say..it looks good, however iam crazy so...i want it to be 100%
ill go to homedepot and look into these chrome rings, i guess u use like double sided tape too hold them into place?
anyone have a picture of the rings installed? or anyother ideas...
Old May 18, 2006 | 12:38 PM
tiojames's Avatar
tiojames
Default carpet fit
Either take the car or the carpet to an upholstery shop and have them sew trim around the bars.
Old May 18, 2006 | 01:47 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Just took a look at mine and always thought they looked great but now i see a new mod for me to do
Old May 18, 2006 | 03:41 PM
uknowme2good
Default ttt
bump
Old May 18, 2006 | 03:56 PM
Alcee1's Avatar
Alcee1
This is what I did.....
Old May 18, 2006 | 04:13 PM
N0TDADYS_98's Avatar
N0TDADYS_98
this is in a coupe?
Old May 18, 2006 | 04:15 PM
Alcee1's Avatar
Alcee1
Uh....yep
Old May 18, 2006 | 04:24 PM
N0TDADYS_98
do you have a pic... zoomed out a little so I can see both in one shot?
Old May 18, 2006 | 04:45 PM
Alcee1's Avatar
Alcee1
I don't have one here at work, but when I go home I'll try and remember to post one for you.
To chrome hoops installed
Old May 18, 2006 | 08:26 PM
Alcee1's Avatar
Alcee1
Heres the shot you asked for......
Old May 18, 2006 | 09:09 PM
Z0SLIK's Avatar
Z0SLIK
Looks great!!
Old May 18, 2006 | 09:57 PM
uknowme2good
Default hoops
looks very good....not a bad idea....
