Air bag question
Old May 20, 2006 | 01:03 AM
IMA 66's Avatar
IMA 66
Default Air bag question
been toying with the idea of adding a C5 to teh stable....figure the wife has a better shot of being able to drive it to shows. My question is can the passenger side airbag be turned off? one of the reasons i want a newer one is so the wife could driv eit to the show with one rugrat while i take the other in the 74 or 66. Course if the airbag can't be diasabled tha tkind of kills that idea.......let me know
Old May 20, 2006 | 01:19 AM
RxConsult's Avatar
RxConsult
In the glove box on the passenger side is a Air Box Off Switch. Put your key into it and turn off the air bag.
Old May 20, 2006 | 02:05 AM
BrianWe's Avatar
BrianWe
, but this was only true on the later model C5's. I'm not sure of the year this became standard.
Old May 20, 2006 | 05:46 AM
Cajun99's Avatar
Cajun99
Here's a good idea of how to install the cut-off switch...
http://97vette.com/howto/airbag/index.html
Here's where you can get the parts...
http://temp.corvetteforum.net/c5/ken...rtspage3.shtml
Old May 20, 2006 | 05:49 AM
Ginzo's Avatar
Ginzo
My 2003 has the keyed turn-off switch in the glove box.
Old May 20, 2006 | 07:32 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
2001 and newer Corvettes come equipped from the factory w/ a passenger side air bag cut-off switch. The older C5's can have an A/B switch installed. I installed one in my '98 a few years ago. Took me a couple of hours. Good luck....
Old May 20, 2006 | 07:53 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mid year 2000 and later came with the switch. I can get the VIN break point, I will have to search the Service manuals.
But it is mid 2000 and later.
The above post has 2 links. They are the best resource. But remember the belt that comes with the kit MUST be changed. Or it will defeat the whole purpose.
I installed the kit last year, any questions, drop me a PM
Old May 20, 2006 | 08:17 AM
On mid-2000 model year and newer cars, they come with a passenger air bag cutoff switch. If you buy an earlier model, they can be retrofitted with the switch. Fichtner Chevy or Fred Beans can get the parts for you.
Old May 20, 2006 | 09:07 PM
IMA 66's Avatar
IMA 66
thanks guys looks like i am good to go with whatever year i get now
Old May 20, 2006 | 10:42 PM
granpastoy's Avatar
granpastoy
It is very handy when the Grandaughter and I go for a ride. Your lovely wife needs one get it for her
To Air bag question
