Lower my Vette??
Old May 20, 2006 | 09:55 AM
gmlefty's Avatar
gmlefty
Default Lower my Vette??
I have heard some talk about lowering thier Vette.
Does this affect the Wheels or the ride?
How hard is this and is it expensive to do?
Did you do front & Back?
Lets see some PIX of these LOWWW Riders!!
Old May 20, 2006 | 10:11 AM
vette747's Avatar
vette747
It is free to lower with what we call on "stock bolt" for about 1 inch. Or cut the busing in the front and buy longer bolts for the rear ($10). I suggest you go with lower on stock bolt first because it is easy to go back. If the bolts are not rusted, the longer part is to jack the car. Ride is a little stiffer. You can also search the forum. There is a ton of thread on the subject. If you cut or remove the bushing and install longer botls in the rear, you can get your car very low.
You need to have the car aligned. It increases negative camber and changes the toe.
There are several DIY. I have one on my site with pics. I also have alignment differences.
Click on that link and scroll down to ‘Lowering Your C5’.
http://pages.videotron.com/vette747/
Old May 20, 2006 | 10:17 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I thought all Vettes came lowered, I have the rear as far as they go on the rear bolts and cut the front bushing to lower the front. I have the bolts to lower the rear more and will do this when I change the oil next time as I want the rear to be as low as the front. I upgraded to Z06 Sways and the handling is much better, and I do not mind the rubber air dams hitting as they are cheap to replace
Old May 20, 2006 | 01:25 PM
jrose7004's Avatar
jrose7004
Lowered gives it a special look! The ride doesn't really change but just be sure to get it aligned after it settles for a couple of hundred miles!
Old May 20, 2006 | 02:56 PM
EDJ's Avatar
EDJ
NO 4X4's The lower the better IMHO.
Old May 20, 2006 | 03:07 PM
C5-GIRL's Avatar
C5-GIRL
Lowered is the only way to go
C5-GIRL
Old May 20, 2006 | 03:56 PM
shakainc's Avatar
shakainc
MIne's lowered on stock bolts. But I think I might go a little lower. Drive it for a little while before you get it aligned. It will settle some.
Old May 20, 2006 | 07:43 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
HIGH_INTRESTs car
SW s car
my old car (just picked up a lpm frc)
Old May 20, 2006 | 08:34 PM
Dark Syde's Avatar
Dark Syde
Cruise-In VII Veteran
Every time I get ready to lower it, I hear another horror story from someone that has...
"Pulled in to a gas station and startled a gas fill line, and it was high enough to knock off his resonator"
...was that recent story I heard, and still have not lowered it.
To Lower my Vette??
