rim weight???
Old May 20, 2006 | 06:12 PM
sdef's Avatar
sdef
St. Jude Donor '10
Default rim weight???
Does anyone know what the weight of the typical c5 front and rear rims?
or specifically the rims on a 2003AE vette.
Old May 20, 2006 | 06:14 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
Wheels
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon - Src
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon - Src
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium - Src
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium - Src
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish - Src
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps - Src
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish - Src
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
24 lbs, 18x10.5 - 00+ repro high polish - Src
28 lbs, front; 32 lbs, rear - Z06 chrome repro - Src
23 lbs, front; 26 lbs, rear - Z06 chrome repro - Src
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished - Src
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear - PWO - Src
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center - Src
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center - Src
24/25 lbs - Z07 wheel weight, front - Src
28 lbs - Z07 wheel weight, rear - Src
Lugnuts
1.5 oz - OEM open lugnut - Src
Tires
NOTE: Kumho tires are not currently differentiated between runflat and nonrunflat tires.
29.5 lbs, front; 32.5 lbs, rear - Goodyear EMT, stock size - Src
27 lbs, front; 33 lbs, rear - Bridgestone S03's, stock size - Src
26.4 lbs - Goodyear GS-C 275/40R17 - Src
12 lbs, 275/40x17; 15 lbs, 315/35x17; 16 lbs, 305/30x18 - Hoosier A3S03 - Src
28 lbs, 275/40x17=28lbs; 30.5 lbs, 315/35x17 - Goodyear ZR "S" Rains - Src
25 lbs, 275/40x17; 28 lbs, 315/35x17 (shaved to 6/32") - Goodyear GS CS - Src
23lbs, 265/40x17; 24.5 lbs, 275/40x18; 25.5 lbs, 295/35x18 - Goodyear F1 GS CS - Src
27 lbs, 265/40R18; 28 lbs, 315/40R18 - Goodyear GS F1 SC - Src
25 lbs, 255/40R17 - Bridgestone Potenza S02 - Src
27 lbs, 275/40R18 - Bridgestone Potenza S02 - Src
29 lbs, 285/30R18 - Bridgestone Potenza S02 - Src
30 lbs, 285/30R18 - Bridgestone Potenza S02 - Src
30 lbs, 295/30R18 - Bridgestone Potenza S02 - Src
29 lbs, 295/35R18 - Bridgestone Potenza S02 - Src
28 lbs, 245/45R17 - Kumho Ecsta 711 - Src
29 lbs, 245/45R17 - Kumho Ecsta Supra - Src
32 lbs, 245/45R17 - Kumho Ecsta MX - Src
26 lbs, 245/45R17 - Kumho Ecsta Victoracer V700 - Src
30 lbs, 265/40R17 - Kumho Ecsta Supra - Src
20 lbs, 275/40R17 - Kumho Ecsta MX - Src
36 lbs, 275/40R17 - Kumho Ecsta MX - Src
25 lbs, 285/30R18 - Kumho Ecsta V700 - Src
TBD lbs, 295/35R18 - Kumho Ecsta ASX - Src
30 lbs, 295/35R18 - Kumho Ecsta Supra - Src
20 lbs, 275/35R18 - Kumho Ecsta MX - Src
31 lbs, 295/35R18 - Kumho Ecsta MX - Src
26 lbs, 305/30R18 - Kumho Ecsta V700 - Src
28 lbs, 315/35R18 - Kumho Ecsta V710 - Src
30 lbs, 335/30R18 - Kumho Ecsta V700 - Src
Tire Rack
Kumho ECSTA ASX Specs
245/45WR17 27 lbs
275/40WR18 30 lbs
UTQG: 420 AA A
Avon Tech M550 A/S Specs
245/45WR17 29 lbs
275/40WR18 34 lbs
UTQG: 360 AA A
Avon Tech M500 Specs
245/45WR17 28 lbs
275/40WR18 32 lbs
UTQG: 280 AA A
Continental ContiExtremeContact Specs
245/45WR17 24 lbs
275/40WR18 25 lbs
UTQG: 400 AA A
Kumho ECSTA MX Specs
245/45YR17 25 lbs
275/40YR18 29 lbs
UTQG: 220 AA A
Pirelli PZero Nero M&S Specs
245/45WR17 24 lbs
275/40WR18 29 lbs
UTQG: 400 AA A (front), 400 A A (rear)
BFGoodrich g-Force T/A KDW Specs
245/45YR17 28 lbs
275/40YR18 32 lbs
UTQG: 300 AA A
Goodyear Eagle F1 GS Specs
245/45YR17 25 lbs
275/40YR18 28 lbs
UTQG: 300 AA A
Kumho ECSTA MX (runflat) Specs
245/45YR17 32 lbs
275/40YR18 35 lbs
UTQG: 220 AA A
Continental ContiSportContact 2 Specs
245/45YR17 25 lbs
275/40YR18 26 lbs
UTQG: 280 AA A
Dunlop SP Sport 9000 Specs
245/45WR17 26 lbs
275/40WR18 29 lbs
UTQG: 280 A A
BFGoodrich g-Force T/A KD Specs
245/45YR17 27 lbs
275/40YR18 31 lbs
UTQG: 200 AA A
Goodyear Eagle F1 GS-D3 Specs
245/45YR17 25 lbs
275/40YR18 28 lbs
UTQG: 280 AA A
Michelin Pilot XGT Z4 Specs
245/45WR17 26 lbs
275/40WR18 30 lbs
UTQG: 300 A A
Bridgestone Potenza RE050 Specs
245/45WR17 26 lbs
275/40YR18 28 lbs
UTQG: 140 A A
Bridgestone Potenza S-03 Pole Position Specs
245/45YR17 28 lbs
275/40YR18 34 lbs
UTQG: 220 AA A
Goodyear Eagle F1 Supercar Specs
245/45YR17 24 lbs
275/40YR18 27 lbs
UTQG: 220 AA A
Wheel & Tire combined weight
45 lbs, front - 97-00 OEM magnesium w/Nitto 275/40-17 (1/2 tread) - Src
50 lbs, rear - 97-00 OEM magnesium w/Yoko 295/35-18 AVS Sport non-runflats - Src
47 lbs, front - 97-00 OEM magnesium w/OEM 245/45-17 runflats - Src
53 lbs, rear - 97-00 OEM magnesium w/OEM 275/40-18 runflats - Src
50 lbs, 17x8.5, 58mm offset, front - PWO w/OEM 245/45-17 runflats (1/2 tread) - Src
51 lbs - '06 C6Z GM Stock Wheel/Tire Combo, front - Src
56 lbs - '06 C6Z GM Stock Wheel/Tire Combo, rear - Src
