It was my thinking (probably wrong seeing as how I'd never seen one in person before) that the Z06 gauge cluster had the 'checkered' background pattern and italic print font on all of the gauges in the cluster. However, upon seeing my first Z06 cluster this past week, I discovered that only the tach and speedo on this particular cluster was different from the normal C5 gauge cluster's instruments background and font.
My question is this - is the gauge cluster I described as seeing the cluster that all model year C5 Z06's have or was there any kind of switch over at some year where the gauge cluster was changed in any way?
If so, would someone mind posting a close-up picture of each cluster? Thanks a bunch!
Z06 cluster has just a different tach and speedo with the italic numbers, the z06 logo and the checkered background. also a higher redline on the tach.
The other gauges, fuel, volts, temp and oil press are the same as the regualr c5. All C5 z06 clusters are the same.
