[Z06] C5Z06: Avoiding Breakage at the Drags
But here are some ways folks break them....
(1) Brutalize the tranny with poorly timed shifts near the redline. Breaks synchonizers and shift forks.
(2) Get the rear wheels hopping on launch or the 1-2 shift and then stay on the throttle. Great way to break an axle or the diff case.
(3) Heat the tires at the drags and then dry hop it up to the line. Another great way to break an axle or the diff case.
(4) Burnout dry tires at the drags. More torture for the rear.
(5) Try to heat the tires at the drags, botch it, then try it again without reapplying water to the rear tires. This glazes the clutch or breaks the rear.
(6) Mod the motor to above 390 rwhp and then do hard launches at the drags on DRs. The rear will hate that.
Now, if you avoid the (1)-(6) driving errors, then you can probably make 500+ passes without breakage...like I did.
Good luck with your car.
Ranger
Ranger
So what's recommended when I'm at the drag or on the street for that matter and I bounce off the rev limiter? Engage the clutch w/o shifting and take my beatings??
If you do that and take care of your clutch fluid, then you may never miss a shift. It's the missed strong shifts under power that ravage the tranny.
Hitting the limiter, in and of itself, hurts nothing.
Ranger
Regarding maintaining the clutch fluid, here are the three best thread I know:
Clutch Pedal Woes--Fluid Impact
C6Z06 Clutch Hydraulic Fluid--the Chevy Spec
Clutch Pedal Woes--Fluid Changing Kit
Ranger
Awesome posts again Ranger
Dave
Actually I got a lot farther than most by living within these rules. I have been spraying after my 1st half to full dozen passes with 485rwhp and 5xxtorque and the only up grades where a clutch (stock was fine and sold for $350) and the DTE brace. My tranny still shifts as if it were new, and I pulled everything apart to put in hardened shafts and the driveline/rubbers are in great shape. So, in conclusion, the above advice really works.
Robert
http://www.walgreens.com/store/produ...ush&navCount=0
Ranger
Im guilty of #5 my first time out with the car.
Luckily, my clutch came back to life!
Good advice Ranger.. Everyone should listen!!
Ranger
Now my rearend whines like mad and I'm fairly sure it's no its way out in a hurry.
If you're going to drag race do it on the right tires.
-TJ
I have the spec 3 clutch so i dont think there really is a weak link anymore besides the actual casing on the diff.
Robert
At the big power-levels, each upgrade puts the excess load on the next weakest part.
Ranger
Can you elaborate on what you mean by "dry hopping it up to the line"? I can't figure out what that means!
Thanks!
Thanks!
-Mat-
