[Z06] Help with assembling 410 gears.
Old May 24, 2006 | 10:19 PM
Foxrider 241's Avatar
Foxrider 241
4th Gear
Default Help with assembling 410 gears.
Have 01' Z06 vette that i recently swapped out the 342 gears for a set of 410's and need help with setting up the gears for assembly and adjustment. Any suggestions? and has any one does this yet? thanks.
Old May 24, 2006 | 10:40 PM
97 SC Cobra's Avatar
97 SC Cobra
Ummmm... Could be trouble. I heard you needed like $1500 dollars worth of special getrag tools to properly set up a rear. Maybe someone else can confirm this??
Old May 24, 2006 | 11:28 PM
Foxrider 241
4th Gear
ekk well i have the stock gears out but assembled the 410 gears but do not know how to set them or what kind of settings and procedures need done. thanks gregg..
Old May 24, 2006 | 11:57 PM
97 SC Cobra
Man I don't know what to tell you. I'd let a pro reassemble it if it was my rear. Backlash and shimming and all that crap, not worth a whining rear and possible damage if you get it wrong.
Old May 25, 2006 | 07:21 PM
Foxrider 241
4th Gear
Anyone out there that could help?
Old May 26, 2006 | 09:50 AM
theDarkness's Avatar
theDarkness
I agree with Cobra on this one. You can try posting the question on the autocross section, they usually have something about rearends on there. I would hunt down a pro set backlash and shimming.
To Help with assembling 410 gears.
