Codes reset - how to?
Old May 26, 2006 | 07:59 PM
mitchcole's Avatar
mitchcole
Default Codes reset - how to?
Tried the search - couldn't find it. I have a check engine on due to a plugged air intake for the smog police. I unblocked it and am looking to reset?
Thanks in advance!
Mitch
Old May 26, 2006 | 08:07 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
This should help you out.
http://www.stengel.net/diccodes.htm
Old May 26, 2006 | 08:10 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
Turn the key to the ON position, but don't start the engine.
Clear any present messages by pressing the RESET button.
Hold the OPTIONS button down, and press the FUEL button 4 times.
This will get you into the CODES section of the DIC.
The computer will automatically display all the codes your car has created.
It will cycle through each code every 3 seconds.
Any code that ends in H is a history code (something that has occurred in the past) but is fine now.
Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode.
It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES".
Press OPTIONS to go to the next module.
Repeat the steps in this paragraph until you have reset the codes in all the computer modules.
Old May 26, 2006 | 08:20 PM
mitchcole's Avatar
mitchcole
all I had to do was hit the reset button - who'd have thought!
To Codes reset - how to?
