Bad temp sensor
Old May 28, 2006 | 03:43 PM
CubSmurf's Avatar
CubSmurf
St. Jude Donor '06
Default Bad temp sensor
So, it appears my temp sensor for the AC is bad. It's currently 90+, but the car says it's only 27 degrees. I was doing some searching, and I read that if I just disconnect the sensor it will revert to 65. So, I looked, and i think I found the connector....disconnected it....and stuck on 27 still....do I need to reset something? Or did I disconnect the wrong sensor? When I was looking at the car, straight down from the passenger headlight near the foglight area....was this the correct one?? THANKS!!
Old May 28, 2006 | 04:32 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I can't remember if you get to it from the top or the bottom. The first connector you'll see from the top on the passenger side by the headlight is for the underhood light. The temp sensor is way below that.
jeff
Old May 29, 2006 | 01:49 AM
Does sound like the sensor is bad. It's a cheap part and easy to replace.
To Bad temp sensor
